Author Topic: A helium balloon floats...it is lighter then air and a vacuum is lighter then He  (Read 8130 times)
Online IanB
If you work out how much all the air in a typical room weighs, the answer is surprising.
Offline BeaminTopic starter
  • If you think my Boobs are big you should see my ba
pv=nRT = a lot. When they make precision weights they have to account for the volume and the air pressure it takes up.
Max characters: 300; characters remaining: 191
Images in your signature must be no greater than 500x25 pixels
