Author Topic: Binary (additive) resistor or capacitor box  (Read 1201 times)
Offline etiTopic starter
  • MOD: a.k.a Unlokia, glossywhite, iamwhoiam etc
« on: December 11, 2022, 05:09:43 am »
Has anyone ever made a resistor or capacitor box (thumb wheel selectable increments) which works like this:
[jumper 0 ohms] [1 ohm] [2 ohm ] [4 ohm] [8 ohm] [16 ohm] [32 ohm] [64 ohm] [128 ohm]
You'd have all those resistance values and switch them in and out of series with the other resistors to additively create any ohmic value from 0 ohms to 255 ohms. To do the same for capacitors, you'd just switch the values in and out of parallel connection with the others.
This is binary of course.
I hardly think this could be a new thing I'd thought of. Ideas?
Online Ed.Kloonk
  • Cat video aficionado
Re: Binary (additive) resistor or capacitor box
« Reply #1 on: December 11, 2022, 06:56:02 am »
Use a 8 position dip switch.
https://www.ato.com/8-position-dip-switch
The sub 10 ohm setting precision might drive you bonkers.
« Last Edit: December 11, 2022, 06:57:57 am by Ed.Kloonk »
iratus parum formica
« Reply #2 on: December 11, 2022, 07:14:27 am »
Hence me saying thumb wheels would be used. Yeah it would be a silly design to use DIP switches.
Online ledtester
« Reply #3 on: December 11, 2022, 07:52:38 am »
Teardown of a IET Decade Resistance Box at 3:00:
EEVblog #211 - IET Decade Resistance Substitution Box -- EEVblog
https://youtu.be/37gYHdY0DAM?t=3m
It uses only 5 resistors per decade in a 1-2-2-2-2 pattern. It uses a custom wiper pattern to accomplish this.
I recall there being a project discussed on the forum where a custom pcb was developed for an existing thumbwheel switch and then you could get that pcb manufactured at pcbway/jlc pcb/etc. to create some sort of substitution box -- can't seem to find it at the moment.
« Last Edit: December 11, 2022, 07:54:29 am by ledtester »
The following users thanked this post: Ed.Kloonk
Online Ed.Kloonk
« Reply #4 on: December 11, 2022, 08:14:00 am »
I had forgotten about that. Gee, you're resourceful.
Offline Tigerwoods
  • Country: cn
« Reply #5 on: May 07, 2023, 04:57:09 am »
For binary box better use relays to handle the switching, since there are 2^n combinations that beyond the capability of mechanical switch. Google "programmable resistance box" you may find such products.
I love peace, alright let's fight.
Offline Benta
« Reply #6 on: May 07, 2023, 07:40:57 pm »
It's an attractive idea, but the problem is that you'd need a thumbwheel switch that places the resistors in series. Never seen that.
Your idea would place them in parallel.
On the other hand, it would work for your capacitor box.
Offline Zero999
  • 0999
« Reply #7 on: May 07, 2023, 09:00:56 pm »
Just use a rotary switch for each decade.
9 x 1R
9 x 10R
9 x 100R
etc.
By the way, the original poster has been banned. Is it worth keeping the thread alive?
Offline Benta
« Reply #8 on: May 07, 2023, 09:13:56 pm »
Really? Is that what the blue non-smiley indicates?
Offline tooki
« Reply #9 on: May 08, 2023, 07:26:38 am »
Based on the moderator’s comment added under the name, I guess the ban was for having multiple usernames, which is the only TOS violation they seem to enforce very diligently here. So maybe OP is still around under one of those other names.
