Author Topic: BLDC motor from a floppy drive  (Read 2227 times)
Offline tbjTopic starter
« on: April 30, 2015, 05:22:49 pm »
Hi.
I salvaged this BLDC motor from a floppy drive and it doesn't appear to have a hall sensor. I'm wondering if the axial inductor is used to sense rotor position instead?
Any ideas?
Cheers :)
Re: BLDC motor from a floppy drive
« Reply #1 on: April 30, 2015, 05:40:31 pm »
There will be 3 hall sensors there, probably buried under the steel backing plate. The axial inductor around the edge is there for the rotational velocity feedback loop only, and the tacho pulse.
