Author Topic: So Much Junk Being Sold - Now landscape wiring connectors  (Read 406 times)
Offline xrunnerTopic starter
  • hp>Agilent>Keysight>???
« on: December 12, 2024, 01:16:33 pm »
So much junk being sold ...
Installed these new landscape wiring connectors in the Spring when I did a small project fixing up and cleaning up the landscape lighting outside my front door. I replaced the crappy connectors sold years ago which were starting to fail with this new design being offered by many sellers. They claimed this -
22Pack Low Voltage Waterproof Replacement Landscape Light Cable Connector
Waterproof? They have already failed. Yesterday I had to see why some of the LED lights were flickering. Turns out the connectors were completely ruined by water ingress. Corrosion ate them alive in less than a year.
Like I said - so much junk being sold out there I can't keep up anymore.  :palm:
Online Siwastaja
Re: So Much Junk Being Sold - Now landscape wiring connectors
« Reply #1 on: December 12, 2024, 04:49:28 pm »
by many sellers.
You mean, like Aliexpress / Ebay? If yes, I'm not surprised.
« Reply #2 on: December 12, 2024, 05:13:39 pm »
by many sellers.
The usual suspects of course, but these came from Amazon. I'm working on a product review with pics ...  :box:
Online Analog Kid
« Reply #3 on: December 12, 2024, 07:14:53 pm »
Were those filled with any kind of gel, or just supposed to be a better (presumably water-resistant) design?
The gel-filled ones are supposed to be pretty good, though I've never used them.
A friend who did landscape lighting wiring said the hell with any connectors like these and just soldered everything. Sounds to me like the way to go.
« Reply #4 on: December 12, 2024, 08:20:34 pm »
Turns out they were not filled with gel. I didn't take them all the way apart when I installed them because I didn't have to, to get the bottom wire in (the wire going to the LED light). The top of the thing connects to the main supply line with needle style probes like has been done forever for this type of wiring. The bottom is not filled with gel at all, and so there is nothing at all to keep out water. Anyone claiming these are waterproof or even water resistant needs to put away the crack pipe while writing.
Irrigation wiring uses gel-filled connectors which work well to keep out the water.
Yes and that's what I'm contemplating doing from now on. I dunno who comes up with these types of designs for landscape lighting wiring connectors, but I don't think they hang out on this forum.  :-//
