Author Topic: Strip/veroboard on digikey  (Read 6691 times)
Offline hanndoddiTopic starter
  • Country: is
    • twitter
« on: March 21, 2013, 12:09:19 am »
Hello every one i was looking for veroboards on digikey supriced i did not find any.
Either digikey is not selling veroboards of the have a different name.
Does any one know?
Or maby know a different name used?
And other Q: I looking for a big veroboard A4 size any one know how big veroboards go?
Kv. ├×├│rarinn
Offline c4757p
  • adieu
Re: Strip/veroboard on digikey
« Reply #1 on: March 21, 2013, 12:18:09 am »
I doubt DigiKey sells stripboard. I keep some around for quick, bodgey prototypes; I get it here.
Here is a 205x410mm one, just 5mm shy of A4 in width and longer than A4.
Online mariush
« Reply #2 on: March 21, 2013, 12:34:38 am »
Farnell/Newark has a lot of prototyping boards... but they're not cheap and they may only stock a large percent of them in UK (so you would have to pay 20$ or something like that on each package):
http://www.newark.com/jsp/search/browse.jsp?N=201028+422&ref=lookahead
I personally tried the Roth 100x160 mm veroboards and they're of very good quality, FR2, can't complain, but like I said they're not cheap.
There's boards that look good on eBay for less money, so when I need more boards, I'm probably going to give a few sellers a try.
« Last Edit: March 21, 2013, 12:36:48 am by mariush »
Offline Psi
« Reply #3 on: March 21, 2013, 12:35:54 am »
Digikey seem to have quite a few names for it, breadboard, PC board, Vectorbord, Circbord.
Its all under 'Prototyping Products' - 'Prototype Boards Perforated'
http://www.digikey.com/scripts/DkSearch/dksus.dll?x=0&y=0&lang=en&site=us&KeyWords=V2018-ND
« Last Edit: March 21, 2013, 12:39:56 am by Psi »
Offline c4757p
  • adieu
« Reply #4 on: March 21, 2013, 12:39:10 am »
Psi, I stand corrected! Didn't think they'd have it, but I didn't bother to check.
Offline FenderBender
    • The Solid State Workshop
« Reply #5 on: March 21, 2013, 09:36:10 pm »
You can find much better ones on eBay from Chinese sellers, in my opinion. I've bought many FR4 double sided, plated-through-hole proto boards off eBay for relatively cheap.
Offline c4757p
  • adieu
« Reply #6 on: March 21, 2013, 09:43:01 pm »
I actually really like the traditional stripboard for quick stuff. Single-sided means I can run bare wires anywhere on one side without worrying about contact, phenolic means it's ridiculously easy to cut - I just score it with a knife a couple times and snap, and the strips can eliminate a lot of wires if you're clever with placement. A quick twist of a sharp drill bit breaks the strips easily. I think I'd just run off a PCB (takes me about a half hour from layout-complete to holding the board in my hand) for anything that I'd use that style of board for.
