Yes I have and a response from mojo-chan was deleted.
I do not see it in the deleted posts section of the forum where all deleted posts automatically go.
If it didn't need to be said I would not have said it.
You broke the rules, your post got deleted based on moderator discretion who happened to read it.
This will not be debated any further, it ends here. That goes for you, Mojo-chan, and anyone else who wants to debate who was right and wrong or why a comments was justified etc.
IMO posts should not be deleted unless they are bad enough to justify banning the poster. If you don't like 'one strike you are out' then use a warning/infraction scheme. It looks like SMF has one built in.
We do give warnings, and users can be put on a watch list. Warnings are still a method we chose to use at times.
Let's say an otherwise excellent contributor with thousand of great posts, can't help themselves venting once of twice in a thousand posts.
Which is better:
- (how it currently works) Simply deleting the offending post so that no one has to read that crap. (They almost always contain no useful information, or a post is edited to remove the personal attack or whatever but leave the useful stuff). The forum continues to run smooth as silk, newbies don't get to see the vitriol, and hence don't think either the forum is crap because of that, or it's ok to write that stuff. And regulars get a hint that if you step out of line too far, your post could be removed. Serial offenders get banned as per usual, usually after a warning or two.
- Three strikes and you are banned, no questions asked, no taking into account your standing or contribution, all for the occasional small outburst many can't help.
- Ban the user immediately
Door #1 is what I chose, and it's proven to work well for 5 years now, I have no plans to change it.
