Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
General
General Technical Chat
Using PCB as Direct connector for USBC
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: Using PCB as Direct connector for USBC (Read 539 times)
Regenerate3d
Contributor
Country:
on:
May 11, 2023, 11:01:10 pm »
Hi All,
Looking to make a FDTI device as small as possible and with as few components possible.
I've seen a connector on a PCB please see attached image. Can anyone point me in the right direction with a footprint etc. I'm using Kicad to design the PCB.
Many thanks
Logged
Regenerate3d
Contributor
Country:
Re: Using PCB as Direct connector for USBC
Reply #1 on:
May 11, 2023, 11:29:02 pm »
Sorry I forgot to attach image.
Logged
jpanhalt
Super Contributor
Country:
Reply #2 on:
May 12, 2023, 09:33:55 am »
Seems to be here somewhere around p.42:
https://www.usb.org/sites/default/files/USB%20Type-C%20Spec%20R2.0%20-%20August%202019.pdf
Or, at least those dimensioned layouts can help you build your own.
Logged
tooki
Super Contributor
Country:
Reply #3 on:
May 12, 2023, 02:59:56 pm »
0.6mm, with 0.5mm on each side for contacts to stick up, total thickness 0.7mm ±0.05mm. 0.8mm PCB is just a tad too thick, and might damage the plugs.
Logged
DavidAlfa
Super Contributor
Country:
Reply #4 on:
May 12, 2023, 09:54:57 pm »
I have a cheap UV lamp that comes with screen protectors, to harden the glue.
PCB is 0.6mm thick. Inserting width is 6.4mm.
Logged
Hantek DSO2x1x
Drive
FAQ
DON'T BUY HANTEK!
(Aka HALF-MADE)
Stm32 Soldering FW
Forum
Github
Donate
Print
Search
Pages: [
1
Go Up
« previous
next »
General
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
