Just a thread to show off your builds should they fall under the correct category
(some images will probably follow when i get home later.)
Note that your build doesn't have to actually be a PC, it could be a frankenstien'ed Home theatre, or that fish tank that is kept at a controlled temp via the use of changing the clock speed of a pentium 4
Categories:
- Master Of the Art Of Sketch
No, i'm not talking about your inability to cable manage (well, ok, most sketch builds will have none) I'm talking more along the lines of A pc made using questionable parts, or questionable use of good parts. Like a DIY liquid cooler, or using PATA cables as a power bus. This will probably be the best category.
- Past it's first prime
Do you have your pentium three, once a proud rendering machine, sorting files? Perhaps you're too cheap to buy a new PC so you somehow manage to reuse your ancient rig to "somewhat decently" game on?
- Pointless automation
There probably won't be as many in this category, some sort of DIY home automation the either does something ridiculous (When you get home, you are greeted by the sound of tesla coils saying your name) Another example that is *somewhat* safer and more possible, your TV remote controls your lights, blender, microwave, quadcopter, PC, doorchime, HVAC, pool, BBQ.
