Author Topic: BPW41N it is a linear sensor ?  (Read 706 times)
Offline harrysmithTopic starter
  • Country: dz
« on: September 24, 2020, 03:18:44 pm »
hello community. I hope you are well
I would like to know is that the BPW41N sensor is a linear or non-linear sensor with justification. thanks
Re: BPW41N it is a linear sensor ?
« Reply #1 on: September 24, 2020, 04:18:20 pm »
Quite linear if used in a current source mode into a virtual ground at an opamp input, and,like any photodiode, not linear in voltage source mode, though running it with a bias voltage probably will be reasonably linear.
Datasheet here, https://www.vishay.com/docs/81522/bpw41n.pdf so yes it is reasonably linear within a range, though low light and bright light levels is going to make it non linear at the high end, and noisy at the low end.
Offline Halcyon
  • Global Moderator
« Reply #2 on: October 08, 2020, 09:43:34 am »
Please stop posting the same questions in individual threads. Use the existing thread you have. You are on notice.
