Author Topic: Breadboard Jumper Wires  (Read 4886 times)
Offline ExcavatoreeTopic starter
« on: September 24, 2022, 10:04:46 pm »
It's been almost 32 years, exactly since I've purchased breadboard jumper wires.  (the type with two 90 degree bends)
On my old sets, the wires are color coded.  The tiny, uninsulated ones weren't, of course, but the red wires jumped over two breadboard sockets/spaces, the orange jumped over three,  and so forth according to the resistor colors.  I notice a lot of sets being sold don't have this color code anymore.  Am I the only one who ever used it?  Does anyone still buy these, or do most use just use whatever scraps of wire one has, or use the kits without coding?
Online ledtester
Re: Breadboard Jumper Wires
« Reply #1 on: September 24, 2022, 10:37:08 pm »
I've had a couple of those multi-colored breadboard wire kits, but inevitably you start to lose them. Also, I found that I rarely used the longer wires and often ran out of the shorter jumpers -- like the 1 to 4 length ones.
About 10 years ago I had some jumpers that had machine pins on the ends and they were really nice but also expensive. Today you really can't beat the price of the "Dupont" style jumper wires or the ones that come with the molded plastic ends. You don't get the variety of lengths but often it doesn't matter if your jumpers form big loops in the air. When it does it's back to making your cut-to-length jumpers.
... or do most use just use whatever scraps of wire one has,
I like to use 22ga solid core wire when I have to cut my own jumpers, although 24ga also works.
Video on how to measure a wire for a custom breadboard jumper length:
Chip Tips #6: Beautiful Breadboards -- Robery Baruch
https://youtu.be/4F3NueYBQUg
Video description has a concise summary of the calculation.
« Last Edit: September 24, 2022, 10:39:56 pm by ledtester »
The following users thanked this post: Excavatoree
Offline www.MKRD.info
« Reply #2 on: September 24, 2022, 10:50:34 pm »
I will give you a hint: less features: cheaper and easier to produce: higher sales profit.
« Reply #3 on: September 24, 2022, 11:27:42 pm »
I know that; I was just wondering if I was the only one who ever appreciated and/or used the feature in the first place.   If one doesn't care, then one buys the cheaper version, naturally.
I'll be honest, I almost ordered one of the cheap set made with whatever wire they had laying around, I was studying the pictures and finally noticed.
Online Someone
    • send complaints here
« Reply #4 on: September 24, 2022, 11:33:56 pm »
Its a general divide in how to mark reusable wires/cables:
Colour by length: you can quickly pull the right item from the box/tangle
Mixed Colours: you can colour code the assembly/installation/system
Which do you spend more time on? Picking out the wire to use or trying to figure out where the wires run/connect?
Offline Circlotron
« Reply #5 on: September 24, 2022, 11:41:00 pm »
I use the wire that comes in telephone cables. It’s perfect.
The following users thanked this post: Ed.Kloonk
« Reply #6 on: September 25, 2022, 12:00:08 am »
That brings back memories.  When I was 7, Dad got me a "50 in one" kit and a bundle of telephone wire.  Seems the phones in his office were just re-wired and he saved some scrap.
Later in life, I was one of the last people to install the phone systems that used the 25 pair cable.  I used to have all the colors memorized.
Offline Warpspeed
« Reply #7 on: September 25, 2022, 02:53:26 am »
Just go to your local hobby store and buy a spool of "doorbell wire".
Its solid core and comes as a pair, which you can easily split.
A one hundred foot roll of that has two hundred feet of breadboard jumpers.
If you live to be 103 you will still be cutting short lengths off that same roll.
Offline rdl
« Reply #8 on: September 25, 2022, 08:45:33 am »
I have a couple of boxes with those kind of color coded wires. I don't like them and rarely use them. I want some where every length is the same color and available in at least 5 or 6 colors. I'd buy many boxes of them. This is because I prefer color coded connections whenever possible, so usually I just cut my own. They often need to be short and to the point anyway, not big looping antennas.
Offline mathsquid
  • I like math.
« Reply #9 on: September 25, 2022, 07:07:17 pm »
I do the same thing. With all those conductors, even a scrap piece of cable can give you a lot of jumper wires. For longer pieces I take the twisted pairs, put one end in my drill and the other in a vise, and slowly untwist them.
Offline rdl
« Reply #10 on: September 25, 2022, 09:37:37 pm »
Don't most phone cables use 24 gauge wire these days? I tried some 24 gauge wire for breadboarding once, but it just seemed too loose. I dunno, it should work I guess. I bought a bunch of rolls (7 or 8 colors I think) of 22 gauge solid years ago and that's all I use.
Offline aeberbach
« Reply #11 on: September 26, 2022, 12:48:40 am »
You can buy a boxed set of 3M Jumper Wire pre-cut and very likely in the colors you are used to, just over $100 at the local distributors. Mfr part no. "923351-I", aka "JW351K" should find it. These I carefully remove and put back in the box when done. Not sure if I paid that much for the box!
Alternatively I picked up a set of reels of 6 colors of "Tuofeng" 22AWG solid insulated wire. I cut it to required length, strip and use, then often discard when that circuit is done. I believe 22AWG is about right, I remember trying to use solid network cable wire and it was a bit loose. Perhaps an issue if your breadboard has had a few uses and no longer grips as tightly?
« Last Edit: September 26, 2022, 01:29:07 am by aeberbach »
Software guy studying B.Eng.
Offline MegaVolt
  • Country: by
« Reply #12 on: September 26, 2022, 02:52:57 pm »
« Reply #13 on: October 04, 2022, 09:22:58 pm »
Sorry to drag this one up, but I'll add some final thoughts.
"Someone" mentioned color coding by length vs color coding by function of the wire.   At the University the circuits were relatively simple, and the goal was to build them quickly, take the data, and then move on to the other 10 assignments I had to do.  So, the color code by length was better.   More complicated circuits that one might be designing would benefit from color coded by function.  Hence, cutting one's own wires as one needs them is better, as it's impractical to store every length in every color.
The kits sold now, in the random colors, would be perfectly OK, as I know I'll eventually get used to the new colors, but the resistor colors are burned in my brain a lot better.  I do worry about the lengths.  The kits sold have wires cut in mm lengths, and some are up to 6 percent off from the breadboards .1 inch spacing.  Worse, they are short, so one can't even put an arch in the wires to make them work.
What did I do?  I went to the famous auction site and bought some old kits from people who took electronics a long time ago and are finally cleaning up.   I did end up cutting some, because one set I bought had the longer wires mangled badly.  (seems someone just said "screw it" and used long wires for everything, and made them fit.)  I notice there are 1 inch wires, and 2 inch but nothing in between, so I made some.
Thanks for indulging me, and I thank everyone for responding.
Offline rstofer
« Last Edit: October 04, 2022, 11:58:04 pm by rstofer »
Offline aeberbach
« Reply #15 on: October 05, 2022, 06:13:13 am »
I bought the Knipex 12-62-180 strippers shown in that YouTube video. They're good!
Offline Dave Lowther
« Reply #16 on: October 05, 2022, 09:23:50 am »
I make my own out of single core insulated wire from a 25m reel I got a long time ago. I keep them in zip bags marked with the number of gaps they span. This works well for me.
Offline MikeK
« Reply #18 on: October 05, 2022, 01:45:48 pm »
Unfortunately, the Amazon kit uses 24 gauge wire, which may be a bit loose in some breadboards.
Yet another reason I bought a couple old sets.    Some use fewer colors to lower cost, but some sets use all the colors from brown to white, but mix them up.  As I said above, I'd probably get used to it, but the resistor colors are already burned into my brain.
« Last Edit: October 05, 2022, 01:48:34 pm by Excavatoree »
Offline RoGeorge
« Reply #19 on: October 05, 2022, 02:00:49 pm »
Offline rsjsouza
  • Eternally curious
    • Vbe - vídeo blog eletrônico
« Reply #20 on: October 05, 2022, 02:12:22 pm »
One interesting aspect that I have noticed is that my older set of 22AWG sometimes have a hard time being plugged into the über cheap breadboards. Sure, I probably shouldn't have those around, but they work well for the most part and therefore may benefit from the smaller diameter.
All my higher quality boards, however, work very well with the 22AWG gauge.
Telephone cables work very well as a source of breadboard wire, but LAN cables are a lot thinner and do not make a good connection even on my cheaper breadboards.
Offline RoGeorge
« Reply #21 on: October 05, 2022, 03:35:45 pm »
I've just measured the LAN copper wire, mine is exactly 0.50mm diameter, which means AWG24.
It's the same thickness as the terminals of a glass body 1n4148.
Some resistors have even thinner legs, of only 0.35mm (AWG27).
LAN wires' AWG can vary:
Cat5e cables usually run between 24 and 26 AWG, while Cat6, and Cat6A usually run between 22 and 26 AWG.
Source:  https://www.cablesandkits.com/learning-center/what-does-AWG-mean-for-Ethernet-patch-cables
« Last Edit: October 05, 2022, 03:40:23 pm by RoGeorge »
Offline MikeK
« Reply #22 on: October 05, 2022, 03:59:12 pm »
What I like about the older stuff is that the jacket is thinner and more suitable for breadboard use.  Thick-jacketed wires on a breadboard is annoying to me.
Offline MarkF
« Reply #23 on: October 05, 2022, 05:51:49 pm »
I use the wire from telephone cable as others have shown above.
I also bought some wire with connectors (see similar from Amazon):
   https://www.amazon.com/Solderless-Flexible-Breadboard-Jumper-100pcs/dp/B005TZJ0AM?th=1
Offline Circlotron
« Reply #24 on: October 05, 2022, 08:54:42 pm »
Just for interest’s sake I measured this wire. It is pretty well exactly 0.5mm diameter.
