A four wire test along the full length of a power bus, with the forcing wires in the outermost pair of holes and the sense wires in the next pair of holes, the distance between the sense wire holes, together with accurate measurement of the individual contact finger width, the total width of the metal in the base of the strip including upturns and the thickness would be the minimum required to get an approximate figure for the resistivity that could be compared to that of various candidate alloys. Its probably not worth it unless you have known good breadboards to compare to, due to the wide range of resistivity of cuprous alloys depending on their composition and purity. However a resistance per inch figure for the bus bars, excluding contact resistance, could be a good metric for comparison to separate the good from the bad and ugly.
