Author Topic: Breadboarding SMD's  (Read 12137 times)
Offline FreeThinkerTopic starter
  • Truth through Thought
Breadboarding SMD's
« on: January 26, 2012, 06:48:39 pm »
Dave raised a very significant point in one of the threads about the power supply project Just how DO you develop a circuit using SMD devices? You cannot breadboard them so that leaves simulation or building a pcb. How do you develop a circuit idea? Building a pcb is not great for a one off and simulation can be tricky and not 100% realistic so which method do you choose and why?
Machines were mice and Men were lions once upon a time, but now that it's the opposite it's twice upon a time.
MOONDOG
Offline MarkS
Re: Breadboarding SMD's
« Reply #1 on: January 26, 2012, 06:52:56 pm »
You can breadboard SMDs. In fact, they make SMD breadboards (protoboards). I've even seen people solder SMD resistors and caps between the pads of standard through hole breadboards.
HLA-27b
  • Guest
« Last Edit: January 26, 2012, 07:19:04 pm by HAL-42b »
Offline robrenz
  • Real Machinist, Wannabe EE
« Reply #3 on: January 26, 2012, 07:03:48 pm »
Dave has showed the dead bug style ( glue chip down on its back and solder individulal wires to each pad) in one of his videos. Also you can get semi universal adapters that have the smd footprint that you solder your smd chip to that are connected to .1 spaced pins that you plug into your standard breadvboard.
Sorry for some duplication HAL-42b  I ignored the additional post warning when I posted this.
« Last Edit: January 26, 2012, 07:06:40 pm by robrenz »
Offline Bored@Work
« Reply #4 on: January 26, 2012, 07:09:43 pm »
I have this http://www.elecfreaks.com/store/flower-22-protoboardmega-shield-p-378.html on my list of things I want to check out when time permits. A prototype board for SMDs with a very specific pad layout.
Unfortunately they made it into an Arduino "shield", a rather useless form factor, but it should be OK to just check if this new prototype PCB layout works.
« Reply #5 on: January 26, 2012, 07:12:44 pm »
Hmm wouldn't that ruin your breadboard? seems an bit of a kackhanded way to me, but I cannot think of an alternative (yet)
Manhattan style, dead bug style etc.
https://www.eevblog.com/forum/general-chat/point-to-point-wiring-another-marvellous-prototyping-technique
https://www.eevblog.com/forum/projects-designs-and-technical-stuff/has-anyone-seen-this-guy%27s-pcb-enclosures-blew-my-mind
This covers ic's etc but what about discretes (Caps resistors etc) ? again very messy and time consuming.
Is the only way simulation?
MOONDOG
Offline robrenz
« Reply #6 on: January 26, 2012, 07:16:46 pm »
http://www.proto-advantage.com/store/index.php?cPath=2200
large selection of all types of adapters
« Reply #7 on: January 26, 2012, 07:19:59 pm »
B.A.W. Thank you seems to have legs (no pun intended) ;D could even be the final pcb at push for a one off. In the back of my mind I'm remembering a cheap protoboard made (I think) by one of the forum members but I've failed to find it  :'( . Can't remember any details but it's driving me nuts. Thanks again BAW
MOONDOG
Offline gregariz
« Reply #8 on: January 26, 2012, 07:21:40 pm »
If you go into fry's they have a range of smd protopcb's with a 0.1" pitch SIL strip on them that they call SURFboards
http://capitaladvanced.com/products.htm
http://www.frys.com/search?search_type=regular&sqxts=1&query_string=surface+mount+board&cat=0
http://www.frys.com/product/1746547?site=sr:SEARCH:MAIN_RSLT_PG
These little boards allow you to solder your smd's to and then push them into the breadboard.
Edit... or you could just use Bob peases technique
http://electronicdesign.com/article/analog-and-mixed-signal/What-s-All-This-Floobydust-Stuff-Anyhow-Part-15-.aspx
« Last Edit: January 26, 2012, 07:28:27 pm by gregariz »
Offline sonicj
  • updata successed!
« Reply #9 on: January 27, 2012, 03:26:04 am »
i blew up 2 caps last night trying to solder smd on regular protoboard before i finally gave up.  ;D
dipmicro has some very nice & affordable smd prototyping paraphernalia for those in the US and Canada.
-sj
Offline Teknotronix
« Reply #10 on: January 27, 2012, 04:25:31 am »
I've used proto advantage as well. Great products.
Don't drone me bro!
Online IanB
« Reply #11 on: January 27, 2012, 05:41:30 am »
Don't say that without giving at least some idea of the tools and technique you used!  :)
What soldering iron? What solder? Did you pre-tin the pad? Did you flux the pad? Did you touch the iron for no more than a second or two?
Any clumsy numkin can destroy SMD components by overheating them. It takes skill to do it right  :D
See examples: http://www.hakko.com/english/tip_selection/work_chip_parts.html
Offline sonicj
  • updata successed!
« Reply #12 on: January 27, 2012, 06:22:52 am »
Well... First, I harvested the parts out of a old laptop using Weller WESD-51 & WTCPT stations chop-stick style.
After removing residual solder with a wick, I tested the parts with DVM.
Soldered the parts into a space clearly not intended for SMD component placement with big puddles of solder and lots & lots of heat.  ;D
Not sure what went wrong...
-sj
Offline JuKu
    • LitePlacer - The Low Cost DIY Pick and Place Machine
« Reply #13 on: January 27, 2012, 09:13:10 am »
Veroboard. Discretes are easy, 0805 fits nicely between pads. Larger discretes can be mounted tombstone style; solder one end of the part and leave the other end pointing up, solder wire to the top. Also, there are SMD protoboards, very handy (Such as the red ones here http://www.seeedstudio.com/depot/prototyping-protoboard-c-175_188.html).
But you need to have right tools and right technique: small tip iron with good control, good flux, thin solder, good vision or a microscope etc.
I much prefer SMD even for prototyping: it is much faster and efficient when I'm able to work on one side of the board only. Besides, a SMD resistor end solders in half a second, a wired resitor tahes about two. :)
http://www.liteplacer.com - The Low Cost DIY Pick and Place Machine
Offline Psi
« Reply #14 on: January 27, 2012, 09:35:32 am »
Here's what i do if i want to put a SOIC into vero or breadboard.
I get a DIP IC socket and solder 1cm of 1--0.5mm single strand wire into the top of each DIP socket hole.
(Normally it's the cutoff leg of whatever resistor/capacitor i have too many of)
I then bend the wires to align with pins on the soic and solder them to it.
« Reply #15 on: January 27, 2012, 10:50:55 am »
Ok now you're starting to scare me  ;D ;D
MOONDOG
Offline aluck
  • Country: ru
« Reply #16 on: January 27, 2012, 11:25:29 am »
BTW, these breadboards should be easily etched at home. One only needs a .pdf or Eagle PCB...
