Author Topic: Does anyone know how to charge the How to charge fat sharkpreditor v2? FPV gglz?  (Read 2231 times)
Offline yadaTopic starter
Do any of you drone people use these? They are my latest Toy going into a tiny airplane.
I have a bench power supply 1-30V with current limiting capability.
What setting should I set it to, to make it charge? The instruction say see your batteries owner manual. 300 bucks and no charger. What the fudge!!!?  |O
Don't I take nice pictures?
Offline kalel
I don't know if this helps:
http://www.manualsdir.com/manuals/636447/fat-shark-predator-v2.html?page=7&original=1
It's the manual page related to charging.
Maybe you will need to search for a "standard" 7.4v lipo pack charger? Or you could check for some details on how a generic charger works when "setting up for 760  mA 7.4V Li-po" as they say.
« Last Edit: June 08, 2017, 02:02:51 am by kalel »
I'm so tempted to plug those banana leads into the power supply and set const. current. I thought I saw a youtube video where some one did this and they just timed it and unplugged it when it was done.
Offline mdszy
  • somehow has an ee degree
    • szy.io
... You're doing RC aircraft stuff and don't have a charger?  :-DD
Get a cheapo IMAX B6 charger ($40USD) and thank me later. It'll save you a lot of trouble -- and be safer! -- compared to charging with a bench supply.
somehow allowed to be a Pixie Wrangler in Training
eBay Store | My site | Hackaday.io Projects | my mastodon.technology profile
I have the charger that came with the battery for the plane. Will that work if voltage is the same but mAh is different?
Offline mdszy
    • szy.io
Yes, it will.
