Author Topic: Built in resistors in PCB  (Read 934 times)
Offline daqqTopic starter
  • Country: sk
    • My site
« on: July 31, 2019, 09:50:49 am »
This is pretty awesome:
https://www.pcbcic.com/wp-content/uploads/2017/10/5-Ohmega_Design_Version_18_1.pdf
Basically resistive material is built into the conductive layers (even internal) of a PCB and the technology seems pretty precise, enabling stuff like termination/pullup resistors on the inner layers between the balls of a fine pitch BGA.
The following users thanked this post: Brutte, ogden
Offline Brutte
Re: Built in resistors in PCB
« Reply #1 on: July 31, 2019, 11:44:30 am »
Carbon ink comes to mind, although carbon ink can be only applied to surface and vias (no internal layers afaik).
I am not sure how to integrate that in a toolchain (managing libraries, testing, DRC, etc). For termination of GHz signals under FPGA it might have its place but in mainstream electronics the access to this kind of service seems quite limited. For analog applications and 3% tolerance - niche market.
I am waiting for a built-in transistor  :popcorn:
Online soldar
« Reply #2 on: July 31, 2019, 03:26:02 pm »
I can see in the future PCBs where the tracks are really printed and the ICs are embedded inside the PCB, not on the surface.
  • Country: sk
    • My site
« Reply #3 on: July 31, 2019, 05:45:17 pm »
Some of this is actually being done already:
https://www.microsemi.com/product-directory/services/3710-package-miniaturization-services
https://nmi.org.uk/wp-content/uploads/2016/10/1-IMAPS_UK_2016_Ostmann.pdf
The initial costs must be insane, but probably worth it.
Offline GlennSprigg
  • Medically retired Tech. Old School / re-learning !
« Reply #4 on: August 01, 2019, 12:00:30 pm »
I was led to believe that some original IC's, had 'Pseudo' components, like....
Very thin 'tracks' as resistors, and very CLOSE tracks as Capacitors ??
Diagonal of 1x1 square = Root-2. Ok.
Diagonal of 1x1x1 cube = Root-3 !!!  Beautiful !!
Online SiliconWizard
Offline @rt
« Reply #6 on: August 01, 2019, 02:15:25 pm »
If I etch the copper I might get a capacitor.
