Author Topic: Bus bar like connector for 2x2x0,8 mm2?  (Read 450 times)
Offline onesixrightTopic starter
« on: June 21, 2022, 11:15:37 am »
Hi All,
I need to connect a ~ 10 cables  (2x2x0,8mm2). It’s a KNX bus cable, so each wires is connected to the other 10 times. I’m looking for 4 terminal block style to do this. It needs (preferably) to be done “permanently” behind a wall, so i’m not planning to access it anymore once its done (and tested).
Looking for some advice what would be the best way to connect those 10 wires in groups of 4?
I found these WAGO 812 series. But I’m not sure if this is they right way to go:
https://www.wago.com/us/rail-chassis-terminal-blocks/busbar-terminal-block/p/812-104
Many thanks!
