Today's map of areas burned near Sydney.
From
https://www.rfs.nsw.gov.au/ Select 'View full-screen map', click the hamburger to get rid of the event list, zoom with scroll wheel. Map updates regularly, sometimes a few shaded sections vanish during updates.
Atmospheric particulates
https://earth.nullschool.net/#current/particulates/surface/level/overlay=pm10/orthographic=-214.18,-28.51,1821
Atmospheric CO (carbon monoxide, from low-temp combustion)
https://earth.nullschool.net/#current/chem/surface/level/overlay=cosc/orthographic=-219.35,-28.63,2048
Mostly this is due to an extreme and ongoing drought, making the bush very very dry. Here's a creek bed somewhere not far from my place, on a day walk a couple of weeks ago.
The larger pools still hold water, but zero creek flow. The walk out of there is an hour, up hill in dense bush on barely a track. That day I was retrieving 30Kg of tools (since I think it will likely burn this summer) and the trip had to be done. Sky full of smoke haze so no way to tell if a fire was starting up nearby. It was scary, and I left early.
Lots of smoke haze days the last few weeks in Sydney. Couple of shots on 20191210:
Bare Island at La Perouse
Georges River near my place.
Today (Sat) I was up in the Blue Mtns. Took some shots at the Three Sisters, looking to the burned areas to the Sth of Katoomba. At least that front of that burn appears to be extinguished.
But other fire fronts are still going. Later on Saturday I was at Lawson, at a commercial storage unit on the edge of the bush. The fire front to the Nth of the highway apparently reached the Grose Valley, and this was the result.
That is not a cumulus cloud, it's a huge hot smoke updraft, from a large amount of bush going whump. The photo really doesn't capture the scale. Soon after that there were charred leaves falling from the sky. Black leaves can be found all over Sydney. They are not 'burned', rather carbonized by great heat in low oxygen conditions. Carried very high by updrafts like that, then flutter down far away.
Fire alerts were calling for emergency evacuation of Leura, not far from us.
It could be worse. Overall the weather has been calm for weeks. Only a few brief moments of wind, and most days are relatively cool for this time of year. A few hot ones, but definitely not _hottest_ever_ as the BOM claims. Ref:
http://joannenova.com.au/2019/12/hottest-ever-day-in-australia-especially-if-you-ignore-history/ and later.
It's just DRY. If we get sustained strong wind in this dryness... shudder.
This has happened before btw. Google 'Europe's Hunger Stones'. Both the Maunder Miinimum and Little Ice Age in the Middle Ages included severe droughts in the early stages. The rivers in Europe dried up, crops failed, millions starved. People carved laments in the rocks exposed well below normal river water levels. "If you see these words, weep." Those stones are exposed again now. And the Sun is now going into a deep Minimum, expected to be as bad or worse than the Maunder Minimum.
Most of my favorite walking areas are toast. Kanangra-Boyd, Newnes, Budawangs... Dammit. By the time they are recovered, I'll be too old to walk there. Assuming this Solar Minimum drought doesn't go on so long they all turn into desert.
Oh yeah, and much of Sydney's water catchment area is now burned. This is really going to screw the already severe water shortage situation. So go ahead, add a few more million water consumers via immigration over the next few years, why don't you?
