Author Topic: WTF is he thinking?!  (Read 12078 times)
Offline xrunner
  • hp>Agilent>Keysight>???
Re: Is the Phonebloks concept phone even possible?
« Reply #25 on: September 12, 2013, 11:57:05 pm »
"Possible" is a big word. Very few things in this universe are NOT possible, given enough time.
That's what we used to tell the bosses when I was still working. They'd ask us if such-and-such a project was possible. We'd always reply -
"Well, anything is possible given enough time and money"
Offline youbecha
Offline Galenbo
Re: WTF is he thinking?!
« Reply #27 on: September 13, 2013, 12:19:27 am »
What an extreme good idea, he worked hard at it and got a perfect result !!!!
(making a clean video, choose the kind of public stupid enough to believe anything, got shared around on socialistic media, and most of all: with an unexistable product !)
A big marketing career is waiting for him.
Only the pope does better.
If you try and take a cat apart to see how it works, the first thing you have on your hands is a nonworking cat.
Offline Stonent
« Reply #28 on: September 13, 2013, 12:38:32 am »
I used to have an idea where they should make the radio module of the phone a universal part so you can upgrade the phone from HSPA to LTE for example. But now it seems the phones are going the way where they're not supposed to be opened.
Offline Stonent
« Reply #29 on: September 13, 2013, 12:52:56 am »
There's a way I could see this maybe working but not nearly as granular as he wants it.
You'll need to separate the things logically.  All the high-speed stuff will need to be in the same block. CPU/GPU/RAM would all have to be in the same block and provide an external USB and LVDS interface. The radio would interface over USB as well as the camera. Storage is easy, just use MicroSD.
The problem comes is just like a real computer, you need drivers. Unless they figure out a way to provide a generic interface where the block only communicates on a high level.
Problems:
1. Phone would be bigger than now
2. Phone would be more expensive because of less integration. If Qualcomm could make a single chip that does CPU, GPU, RAM, RADIO, BT, WLAN why not?
Offline WarSim
« Reply #30 on: September 13, 2013, 01:15:53 am »
Possible, yes (though not the way they picture it), but  it would be too big, heavy and expensive for anybody to want it.
But look at the positive side.  With all the required interconnects nobody will loose their phone again.
The bag phone is returning and those are too big to loose.  :)
Offline kizzap
« Reply #31 on: September 13, 2013, 05:11:16 am »
A thought came to mind, I don't know how effective it would be, but would it not be possible to use fibre optics for data transmission? leaving only a power requirement for the block connections?
-kizzap
<MatCat> The thing with aircraft is murphy loves to hang out with them
<Baljem> hey, you're the one who apparently pronounces FPGA 'fuhpugger'
Offline peter.mitchell
« Reply #32 on: September 13, 2013, 09:58:30 am »
-kizzap
I doubt it, you'd then need a fiber transceiver to connect to the "components" in the blocks, making the blocks even bigger and more expensive.
