Author Topic: Bypassing Keypad With Magnet (video)  (Read 1227 times)
Offline Ed.KloonkTopic starter
  • Cat video aficionado
« on: July 13, 2020, 03:15:36 pm »
 :palm:
iratus parum formica
Offline HighVoltage
Re: Bypassing Keypad With Magnet (video)
« Reply #1 on: July 13, 2020, 05:14:37 pm »
This guy has many funny videos and educates crooks very well.
Offline Ian.M
« Reply #2 on: July 13, 2020, 06:20:34 pm »
WTF!!!
What were the designers even thinking with their single time-share brain cell?   Isn't it obvious that you just *DON'T* put the 'brain' of an access control system in a location that is less secure than the area it controls?
The *FAIL* isn't that relays can be activated by magnets, its that they control a critical circuit and are there in the first place to be activated.   All the keypad should do is send well-encrypted button presses to the 'brain' which should be the secure side of the door, preferably in a physically locked, robust secure cabinet.
Offline kjr18
« Reply #3 on: July 17, 2020, 12:38:22 pm »
Not a first lock he opened with a magnet. While his videos show how to pick some locks, and might be used by crooks, ultimately he shows what locks are total crap that can be opened with a fork, or a piece of can.
Offline GlennSprigg
  • Medically retired Tech. Old School / re-learning !
« Reply #4 on: July 17, 2020, 01:02:32 pm »
It NEVER ceased to amaze me, when I worked in the security business for even large buildings
and enterprises, how even the SIMPLEST 'mechanical' means would 'circumvent' such Code-Pads etc!  8)
Like NOT CLEANING THEM REGULARLY!!!  (What?).  You walk up to some door access, and see say 4 buttons
that are rubbed 'cleaner' than the rest!  Say... 2,4,6,8.  So you KNOW the code is either that, or say 4,6,8,2...
or 2,6,8,4 etc etc.  30-secs later, your in!!!   Believe me... CLEAN THE KEYPADS!!   :palm:
Diagonal of 1x1 square = Root-2. Ok.
Diagonal of 1x1x1 cube = Root-3 !!!  Beautiful !!
« Reply #5 on: July 17, 2020, 05:56:05 pm »
Should be pushing the buttons with a stick anyway.
The following users thanked this post: GlennSprigg
Offline GlennSprigg
« Reply #6 on: July 19, 2020, 11:07:52 am »
Haha... Yep!!.  Doesn't work though, when the 'pads' are 'Capacitive', or pick up 'RF' from your body!!   8)
I remember many years ago, when an Elevator was installed in a fairly remote/radio-quiet area. It used,
(as a lot of lifts do/did) your body to act as an RF Aerial to detect button touches. However, there was so
little signal strength there, it didn't work!!  Was fine in a City.   |O
The following users thanked this post: Ed.Kloonk
« Reply #7 on: July 19, 2020, 02:01:23 pm »
They also had thermal sensing buttons on lifts, did not work out well in a fire, where the lifts all came to the floor of the fire, and stayed open.
As to the keypads, they are not secure, only really meant to keep opportunity low. Easy to tailgate most of those doors, or social engineer your way inside, and if there is an intercom you simply press all the buttons, you are almost guaranteed that somebody will let you inside without checking who you are.
Offline Ian.M
« Reply #8 on: July 19, 2020, 04:53:40 pm »
Tailgating and not checking visitor credentials are social problems - sack a manager and a couple of 'peons' every month for failing to follow security procedures and most such problems go away.  Of course that's not possible for residential buildings - if the residents don't want to pay for a manned security desk to handle  access control, they'll only get an illusion of security.
The heat sensing lift problem is obvious in hindsight, but as they presumably weren't rated for evacuation in case of fire, may even have saved lives!  Of course from a fire-fighting perspective, it wasn't ideal to have the lift shaft compromised at the seat of the fire, possibly acting as a chimney, increasing the threat to higher floors and depending on the building layout drawing the fire towards an area that probably also contains the stairwell access.
« Last Edit: July 19, 2020, 04:58:42 pm by Ian.M »
Offline GlennSprigg
« Reply #9 on: July 22, 2020, 02:08:12 pm »
Reminds me of another time. (Sorry!).  Regarding intercoms. In one of our major Prisons, I tested the main
control room by hitting the intercom saying "doors 16, 18, 22 & 24 thanks!". I heard Clunk Clunk Clunk Clunk.  :palm:
They were supposed to personally identify you on video, then one door opened/locked at a time. I could have
been a prisoner, and walked outside!  I detoured to the control room & told them off!!  Complacency!!   >:(
