The cable company here named Spectrum (used to be Charter) is coming out with new boxes to present a "new guide customer experience" meaning the on-screen TV guide is all gussied up. They said if you don't get them before Set 11, you would not be able to see the new guide. So I went ahead and said OK come bring 'em and let's see what you got. They brought three to replace my old ones.
When they arrived I saw the design has been changed. Now the thing doesn't even display the time or the channel - there is NO display of any information at all other than the power button, a hamburger menu button for the guide (who would use this button?), and a "reset box" button. No more channel display for those that loved it. See attached pic. And since the new remotes are now RF/IR not just IR, each remote RF is paired to each box, you needn't even see the box anymore. Simply place in closet or under a shelf and say goodbye.
What really irks me is the power consumption. It's as bad or worse than the older boxes. The older ones were always very warm to the touch even when "off". By "off" I mean the consumer presentation/level of "off" by which they turn it off via the remote, but we all here realize that it isn't off at that point. It's only truly off when the thing has it's plug yanked out of the wall socket.
So these new boxes are really bad, even when off (consumer off not plug pulled off) the area at the F connector is so hot it's nearly burning hot, it hurts to touch it. All three boxes I got are the same way. So I decided to measure the power consumption.
I used my Killawatt and found that the power consumed when "on" was 13W. But wait - the power consumed when "off" (not plug pulled off) was 12W! In fact I'd say more like 12.5W because the display was flickering between 12 and 13 W.
One really wonders why this design had to be so wasteful of power when off. One also wonders why there is even an "off" action on the remote, what of necessity is really being turned off?
Any thoughts/comments would be well received in this thread.
