Author Topic: Calculating MTBF  (Read 924 times)
Offline spirailTopic starter
Calculating MTBF
« on: June 07, 2022, 04:26:51 pm »
I'm buying a part that has an MTBF of 5,000,000 hours.
What I don't really understand is how I am supposed to interpret these failures to be distributed.
According to the manufacturer, it follows the MIL-HDBK-217F standard.
I tried to read this standard and it melted my brain somewhat.
It seems to me, that if I buy 1000 of these and put them on my boards. I should be able to calculate the average number of support cases in the first 2 years (i.e. the warranty period I promise my customers).
is it really just 5,000,000 / 1,000 then?
That would be 24*365*2/(5000000/1000) = ~3.5 support cases within the warranty period.
Does this sound right?
Offline AndyC_772
Re: Calculating MTBF
« Reply #1 on: June 07, 2022, 04:56:46 pm »
The failure rate of a product generally follows a thing call the 'bathtub curve', so called because a plot of failures vs time looks somewhat like a longitudinal cross section through a bath.
The steep side is located at t = 0, and represents 'infant mortality', ie. those units which fail prematurely because of some manufacturing defect such as a cracked solder joint or ESD damage. It's because of this part of the curve that we do burn-in and temperature cycling at the factory, if we're looking to sell a product that's required to have very high reliability straight from day one in the customer's hands. Better that a product with a latent defect fails inside your own QC lab than finding it's dead on arrival at the customer's site.
The failure rate then falls close to zero and stays that way for a long period of time. This is the product's normal service life. The factory defects have been weeded out, and the remaining units are working exactly as they should.
Finally, the failure rate starts to slowly rise again, as units start to reach the end of their service lives and simply wear out. Exactly when a given unit fails depends on how it's been used - how hot it's been running, how many temperature cycles and how extreme they were, how many hours/day it was switched on, any stresses to which it's been subjected by the user, its power supply, ancillary equipment, and anything else you can think of that's relevant to your product.
Your warranty should, of course, cover the early life failures, and ensure that customers are into the flat portion of the bathtub curve before the warranty expires. However, once they're into that region, it doesn't really matter how long a warranty you offer, because the expected failure rate is very low anyway. Units that fail may well do so because they're being used outside their design parameters (intentionally or otherwise), so you may or may not decide you want to cover these, and can adjust the length of the warranty you offer accordingly.
Calculating the MTBF of any particular product as a whole is complex, and depends on various assumptions about what happens in the event of a failure. If a component fails, is just that component replaced, or a whole assembly, or the whole product? It makes a huge difference.
Normally when I'm asked for an MTBF figure, I start by picking out any components which have an especially short MTBF compared to the other parts in the design - fans and other moving parts, followed by electrolytic capacitors, then maybe power components that are subject to temperature cycling, or very fine geometry digital semiconductors (these increasingly come with a limited lifetime spec which is strongly temperature dependent). These parts will dominate your MTBF to the extent that you can probably ignore everything else.
The following users thanked this post: Mr.B, spirail
Offline egonotto
« Reply #2 on: June 11, 2022, 11:48:56 pm »
Hello,
AndyC_772 is right.
But as the things are complex, in practice they used the exponential distribution. The constant rate is 1/MTBF.
If one calculate the probability that one of these failes in two years, you got 0.0034979. You see, you are with your calculation very good in green zone.
Best regards
egonotto
Offline jmelson
« Reply #3 on: June 12, 2022, 12:02:44 am »
578 YEARS??  Will the part even be able to be FOUND in 578 years?  Or, will it have disintegrated into dust by then?
Some of this MTBF stuff is just crazy mumbo-jumbo.
Jon
Offline hamster_nz
« Reply #4 on: June 12, 2022, 01:05:07 am »
Jon
If you have 578 units in the field, expect one failure a year... doesn't sound that bad.
