Thanks for the replies. Just to clarify some info, when I mention unsafe levels of EMF, I'm don't mean levels which will instantly be harmful like what Berni mentioned, I'm referring to the levels which can cause damage over the long term. For example there are studies that suggest cell phone radiation can cause cancer after too much long term exposure, or studies which suggest too strong of signals from wireless devices can cause headaches or other health concerns. Some people may argue if this is true or not, but I'd like to be able to measure all devices I reasonably can, visualize the power myself and see how much it drops off at a greater distance, in order to make my own educated choices about the use and placement of these devices to mitigate those potential risks.
I looked into the limesdr that was mentioned by xaxaxa, and it seems to have some advantages, but only goes up to 3.8GHz, so I don't think it will meet my needs since I want to measure 5.8Ghz as well.
For the question about pages that give safe levels in milligauss. I won't put a direct link, but if you google safe "emf levels" all the first results as well as the little preview window use this same measurement.
Thanks for the detailed reply from MrW0lf. You brought up an interesting point about looking for software to do a full spectrum scan. I'll check into that, since it would be good to see the full spectrum at once, although I think i will know the general frequency range of what I am measuring.
I'm curious, you mentioned "Most common problem is AC wiring installed by morons which can turn whole apartments into air core solenoids not to mention danger to wild- and other life by direct electrocution in wetrooms.", do you have any good links or search keywords to suggest so I can read more about this phenomenon later?
I noticed MrW0lf's equipment also measured in V and Vrms. One of my concerns with the HackRF is whether it can actually detect strength. Every photo I see measures the signal in DB, but I'm not sure if this is relevant to what I am trying to measure, since there might be some sort of gain or offset involved. For example, take a typical consumer microphone on a camera, it records sound which is also expressed in DB, but most have an automatic gain. If recording a near silent environment but then someone talks, their voice will show up as a high DB level and sound very loud. If recording a very loud environment like a factory, it adjusts the gain so the sounds seem quieter, then if something truly loud happened like an explosion, it will register a higher DB, however since the gain was set different in each environment, if you compared the videos side by side, the voice in the first video may show the same DB level as the explosion in the other video. So I don't know if I could assume a higher DB level measured by the HackRF translates to a more dangerous EMF level or not.
