Product description:Wattgate 381 Audio Grade Duplex Socket
Overview
Why build a performance power cable only to plug it into the same receptacle that's been in use for almost 100 years? WattGate's 381 is a no compromise solution for the demanding AV enthusiast.
Highlights
Cryogenic heat treat hardened contacts
Solid brass contact construction
Three step 24k gold plating process
Triple wiper design increases contact area
Superior performance over standard receptacles
The reviewWell, I have certainly enjoyed the way the creamy smooth 60hz mains supply improves the capability of the switching power supplies in my home theater equipment to provide the cleanest DC voltage available.
However, I can't but help wonder how much happier I would have been if I had been able to purchase the 381 IG (with its isolated ground minimizing interference) or maybe I would have been happier with the 381 AG, with its pure silver coating clearly synergizing with my all silver signal path.
How in the world is possible to improve the capability of switchmode power supplies with smooth AC? Isn't he aware that wave travels miles and miles from a red, rusty generator that is 60 years old? If he wants the cleanes signal he should shut up and get a linear power supply or even better: paying $12,000 for 12 "audio-grade" lead-acid batteries along with their corresponding 20 farad ultra-capacitors.
That made my day.
