Author Topic: Anyone have an idea? on this part?  (Read 3255 times)
Offline BennyBoyTopic starter
« on: June 06, 2014, 02:43:14 am »
I'm not sure what it is. Any of you ever seen anything like this. It's about the size of a 1/8 watt resistor.
Give a man a fish, and he'll eat for a day. Sell a man a fish, and you'll both eat for a day.
Offline c4757p
  • adieu
Re: Anyone have an idea? on this part?
« Reply #1 on: June 06, 2014, 02:51:39 am »
Diode...
« Reply #2 on: June 06, 2014, 03:03:31 am »
Thank you. I just checked it, and it does act like a diode. The glass case thru me. And it came wrapped in foil, as if it were light sensitive.
Offline Psi
« Reply #3 on: June 06, 2014, 03:05:15 am »
yeah glass diode, could be germainium, check the vdrop
« Last Edit: June 06, 2014, 03:06:49 am by Psi »
« Reply #4 on: June 06, 2014, 03:44:04 am »
With a AA battery(1.53v) Diode reads .95v one way and 1.49v the other way. Does not seem correct?
Offline T3sl4co1l
    • Seven Transistor Labs
« Reply #5 on: June 06, 2014, 03:47:48 am »
You just shorted it across a AA battery?  That can deliver amperes of short circuit current?  To a signal diode?  :scared:
I'm amazed it didn't blow.  Well, depends... if you measured reverse first, maybe the next time, it won't give the same result...
Seven Transistor Labs, LLC
Offline johansen
« Reply #6 on: June 06, 2014, 03:59:35 am »
note that he specified 1.49 the other way.
either the battery is recovering from a short, or the diode is leaky. :-DD
Offline Stonent
« Reply #7 on: June 06, 2014, 04:39:56 am »
That's the great thing about glass diodes, in a pinch they can be briefly turned into a LED.
Offline amyk
« Reply #8 on: June 06, 2014, 12:04:25 pm »
They are light sensitive. Not sure what you mean by "With a AA battery", but I hope you know what the I-V curve of a diode looks like... :o
