I'm new to building audio amplifiers. I have successfully tested a variety of amplifier circuits using RC coupling, so I decided to test a circuit that uses transformer coupling.
I built a two stage amplifier using a CE connected PN2222A transistor in the voltage stage (IC=1mA, VCE=10V) and a CE connected TIP50 in the power stage (IC=300mA, VCE=10V). I have a Hammond 109F AF transformer connected to collector on the TIP50 (2:1 turns ratio). I'm using a value of ro=33.33 ohms for the TIP50's output resistance (VCE/IC). I have 33 ohms of resistance on RE with ~2411 uF of capacitance in parallel. My load is an 8 ohm speaker.
Using R'L = (NP/NS)2RL with R'L=33.33 ohms and RL=8 ohms I should be matching impedance between the TIP50's output and the load resistance using the 2:1 Hammond 109F AF transformer.
The amplifier actually performs quite well. There's very little distortion, and the frequency response is pretty good (better than I expected).
My question has to do with the values of IC and VCE I'm measuring on the power transistor. With no ac signal applied, I expected to see a collector current around 300mA and a collector-emitter voltage around 10V for a properly biased circuit operating in the active region. Instead, I'm seeing a collector current around 56mA and a collector-emitter voltage around 16V. Is this expected, and if so, why?
When I build the same circuit using capacitive coupling on the output, I get the expected results (300mA and 10V).
Thanks, in advance, for your help.
