What happens if you make the period of the square wave shorter?
Don't you need a resistor in parallel with the integrating capacitor to keep the output triangle wave centered around zero and stop it drifting? Remember that any tiny DC offset in your input square wave will be integrated to the limit unless this is compensated.
Out of curiosity, what are your power rails for the op amp?
