Author Topic: Can someone tell the different between u1253A and u1253B?  (Read 2699 times)
Offline Aido4everTopic starter
« on: April 04, 2011, 05:38:09 pm »
What the A/B Stand for?
I noticed that every model of Agilent has an A and B version and the only different i see is the color!!!
Offline insurgent
Re: Can someone tell the different between u1253A and u1253B?
« Reply #1 on: April 04, 2011, 08:23:20 pm »
Other than the color (I don't know if the skins for the B fit the A), the differences are very slight.
There are slight differences in the AC voltage & AC + DC vs frequency accuracy specs and the input impedance specs. To my little-trained eyes the specs seem a little better on the A model except for the input impedance in dual display mode.
Here's a spec sheet with all the gory details:
http://cp.literature.agilent.com/litweb/pdf/5989-5509EN.pdf
Offline implor
« Reply #2 on: April 05, 2011, 07:16:31 am »
Correct me if i'm wrong but isn't the B-series a revision/renewal of the older A-series? about the same specs but with newer modern tec?
Offline mkissin
« Reply #3 on: April 05, 2011, 08:35:51 am »
Looking at that PDF, the A series does indeed seem to be very slightly better, but only if you need a 1GR input impedance at voltages less than 1V (as opposed to 10MR), and only if you spend a lot of time measuring AC voltages at greater than 20kHz.
