Author Topic: Can these old pictures be recovered?  (Read 1121 times)
Online RefrigeratorTopic starter
  • Country: lt
« on: January 24, 2021, 01:26:32 pm »
I have some old pictures from 2016 that are corrupted and i would very much like to recover them. But can they be recovered?
When i check the properties tab they show up as ~1.5meg in size and show the correct date so they're not completely gone but the images themselves are pretty messed up.
I have a blog at http://brimmingideas.blogspot.com/ . Now less empty than ever before !
An expert of making MOSFETs explode.
Offline Ed.Kloonk
  • Cat video aficionado
Re: Can these old pictures be recovered?
« Reply #1 on: January 24, 2021, 01:30:07 pm »
File type and upon what file system?
iratus parum formica
  • Country: lt
« Reply #2 on: January 24, 2021, 01:47:00 pm »
These are .jpeg and they came from an SD card from my old phone (Z1 compact).
Oddly enough all the other pictures are fine but the ones i need are corrupted.
Offline Syntax Error
« Reply #3 on: January 24, 2021, 02:48:59 pm »
I would need to see an original file to ascertain where or how the data is damaged. A corrupted jpeg looks like random set of colored blocks followed by black or no image. What are these, images of the moon or the inside of a pocket? It's possible that just a tiny fragment of the image is being stretched out into the frame to give this cloudy texture. But without an orginal, I could not say if they can be reclaimed. :(
« Last Edit: January 24, 2021, 05:10:33 pm by Syntax Error »
Offline richard.cs
  • Electronics engineer from Southampton, UK.
    • Random stuff I've built (mostly non-electronic and fairly dated).
« Reply #4 on: January 24, 2021, 03:01:56 pm »
A corrupted jpeg looks like random set of colored blocks followed by black or no image. ... It's possible that just a tiny fragment of the image is being stretched out into the frame to give this cloudy texture.
I was expecting blocks, but I guess that's a plausible mechanism to get this cloudy image.
Some JPEG decoders cope better than others with bad files, it's worth trying a few and seeing if you get any different results.
  • Country: lt
« Reply #5 on: January 24, 2021, 03:16:41 pm »
The pictures were supposed to be from when i was rebuilding the engine in my car, i need to see if they contain the engine registration number.
But when i checked the dates with one picture from when i was just pulling the car into the garage before the rebuild it's from 2017 so i actually don't know what's in these jpegs.  :-//
So i guess it could very well be that they're supposed to look like this?  :-//
But why would there be a whopping 91 of these.
Anyways, it looks like the pictures i'm looking for might be in my old phone, which got smashed during the rebuild.  :-BROKE
That's what i get for keeping my phone in my pocket when fumbling the engine back into the engine bay.  :palm:
Offline Ed.Kloonk
« Reply #6 on: January 24, 2021, 03:19:04 pm »
The Samsung Galaxy standard camera app used to have a nasty problem with the jpg encoder only when shooting in panorama. Reading them back on desktop Linux was a no go. Somebody made a python script to reorder the tags in the file, but I never could establish if the phone software was simply following a standard or if the generic open source jpeg reader was broken. The problem disappeared after an update and a wait of about 3 years.
Not saying this is the OP's problem but I wonder if there may have been a setting on the camera during the time of those affected files. Are the file sizes unusual?
https://stackoverflow.com/questions/46802866/how-to-detect-if-the-jpg-jpeg-image-file-is-corruptedincomplete
There's a bit of info on what to look for if you wanna get your hands dirty.
Offline Twoflower
« Reply #7 on: January 24, 2021, 03:39:00 pm »
To me they look like the lens was covered by a finger. Even the vignetting from the optical system in the corners is visible. So I don't think there's something wrong with the file data in itself. Corrupting data to reassemble such images but not creating a single JPEG glitch would be extremely unlikely (as of close to impossible unlikely).
Errors in JPEGs more look like that: https://snorpey.github.io/jpg-glitch/ (To my understanding if you set "Iterations" to 1 a single byte will changed to the value "Amount" at a random position, based on "Seed"). Depending on the position the error is not visible or only changes the brightness. Others get easily visible.
Edit: You should check the embedded Thumbnails. For example using jhead to extract the image:
cd <to your images>
This extracts the embedded thumbnail into a file you can open with any image viewer.
« Last Edit: January 24, 2021, 03:52:10 pm by Twoflower »
  • Country: lt
« Reply #8 on: January 24, 2021, 03:57:59 pm »
I think you're right. I assumed these were the pics i wanted because the pics from before the rebuild and right after were present and these were the only ones i couldn't explain, so i assumed these were the missing pics of the rebuild that were corrupted somehow.
But things don't add up once i check the dates, so be it bigfoot, UFO, or just my hand on the camera, these are not the pictures i'm looking for  :)
Offline Ed.Kloonk
« Reply #9 on: January 24, 2021, 04:02:08 pm »
 ;D
I have heaps of photos of my feet.
The following users thanked this post: Syntax Error
