Author Topic: Can you figure this out...  (Read 6654 times)
Offline MattyTopic starter
« on: November 12, 2016, 09:05:19 pm »
Just for a laugh.  Can you guess what signals are going into the scope...
https://youtu.be/TPWfcFm9oi4
Offline ZeTeX
  • Country: il
  • When in doubt, add more flux.
Re: Can you figure this out...
« Reply #1 on: November 12, 2016, 09:42:43 pm »
Whatever it is, do it with a digital scope, I dare ya.
Offline ataradov
    • Personal site
« Reply #2 on: November 12, 2016, 10:55:01 pm »
X is sine wave, Y is a modulated sine wave?
What problems do you see doing this with a digital scope?
Alex
Offline ZeTeX
  • Country: il
« Reply #3 on: November 12, 2016, 11:01:38 pm »
That most of the digital scopes will not show the wave form so smooth and sharp. I would like like to see it on a digital scope actually to see how good and smooth the wave form.
Offline ataradov
    • Personal site
« Reply #4 on: November 12, 2016, 11:08:18 pm »
I'm far tool lazy to replicate this myself, bu here is a video of Tek doing a reasonable job displaying things and doing some measurements at the same time:
Alex
« Reply #5 on: November 12, 2016, 11:36:15 pm »
Makes no difference.  You can still see the 'ripple'.
Thats 70% right.  There is another 30% to go.
« Last Edit: November 12, 2016, 11:38:15 pm by Matty »
Offline Brumby
« Reply #6 on: November 12, 2016, 11:52:17 pm »
Are you after frequency and amplitude relationships...?
Offline Delta
« Reply #7 on: November 12, 2016, 11:57:44 pm »
X-Y mode, sine waves with a 1 Hz difference?
Offline Brumby
« Reply #8 on: November 13, 2016, 12:09:14 am »
Just eyeballing .....
X axis:
   Sine wave of frequency f ; amplitude according to X axis amplifier gain
Y axis:
   Sine wave of frequency 3f ; amplitude 100%  **
   Sine wave of frequency 3f +/- 1 ; amplitude ~60%  **
   Sine wave of frequency something like 50-60f ; amplitude ~5%  (the ripple)
Z axis:
   No discernable AC input
** There is also a slight frequency variation of the 3f figure of something just under 2Hz
« Last Edit: November 13, 2016, 12:16:19 am by Brumby »
« Reply #9 on: November 13, 2016, 02:46:28 am »
wow Brumby, that's a hell of answer.  But that's not quite it.  I was expecting a more simple answer :)
ANSWER   (highlight to see):
Quick Answer:
X and Y both have a sine waves of different frequencies.
Y also has Amplitude  Modulation added on.
X also has Frequency Modulation added on.
Longer Answer:
As this is a Lissajous curve, X and Y have a ratio of ~3:1, you can see there 3 'curves' on the X axis.
The Y Amplitude  Modulation is very small about 1Hz, to see the bouncing.
The X Frequency Modulation is much higher about 10Khz in this case.
In a previous post I typed 'ripple' in quote marks, which I guess was misleading
Offline Brumby
« Reply #10 on: November 13, 2016, 03:08:09 am »
OK - Yes, it's a Lissajous figure.  Didn't think to include the obvious.
Approximate frequency ratio determined by the number of points of contact on two adjacent sides of a rectangular box containing the figure.  Actual frequency ratio will include the speed of 'shift'.
My first sighting of such was in the logo for the ABC (Australian Broadcasting Commission) television station (VHF Channel 2 in Sydney, in the day.)
A little bit more stylised these days:
Offline jonovid
    • JONOVID
« Reply #11 on: November 13, 2016, 03:14:24 am »
yes something from the Australian Broadcasting Corporation   :-DD
if you want the politics.   ::) its in the datasheet
Hobbyist with a basic knowledge of electronics
Offline Brumby
« Reply #12 on: November 13, 2016, 03:23:40 am »
I speak of it's incarnation at the time of my first encounter.
It became the Australian Broadcasting Corporation some time later ... 1983 I believe.
And, yes, it did have it's fair share of issues with those running the place wanting to maintain objectivity up against the political forces that were in play.
Offline Brumby
« Reply #13 on: November 13, 2016, 03:24:49 am »
... but stuff the politics - I just wanted to make a Lissajous figure of my own.
Offline calexanian
    • Alex-Tronix
« Reply #14 on: November 13, 2016, 05:21:00 am »
We had too make that waveform in the modulation section of intro to electronic communications class. It was said before. X axis sine wave with some ripple or something on it, and y axis sine wave modulated at either a low frequency, or a roll and tumble if its up higher in frequency. Cant tell cause I can't see the scope settings.  I made it with four XR2206 circuits because we also had to modulate the X axis too.
Charles Alexanian
Alex-Tronix Control Systems
Offline Brumby
« Reply #15 on: November 13, 2016, 12:37:33 pm »
This example has a sine wave on the X axis - but the ripple is on the Y axis.
Offline ZeTeX
  • Country: il
« Reply #16 on: November 13, 2016, 05:27:45 pm »
On a 11k$ scope, sure, I meant "cheap" digital scopes..
Online tom66
« Reply #17 on: November 13, 2016, 06:19:17 pm »
My Rigol DS1054Z actually does a reasonable job of YouScope, which is of a similar order. It has no issue at all displaying Lissajous figures.
Offline ZeTeX
  • Country: il
« Reply #18 on: November 13, 2016, 08:28:34 pm »
Who knew, I taught most of the cheap digital scopes will struggle with stuff like that.
Offline ataradov
    • Personal site
« Reply #19 on: November 13, 2016, 09:20:20 pm »
Here is a video of a Rigol DS1054Z doing similar thing:
And here is some coll art that would be impossible on an analog scope (without fast beam blanking):
Alex
