Hey all, I got a delta combination belt and 8" disk sander for free on kijiji due to a blown motor, I fixed the wiring as best as I could but something got caught, and as I was pulling the rotor out, the enameled wire ripped (thanks nagging annoying people when I'm working) and in a spot where I can not access it or fix it, so I'm stuck getting a new motor.
There have been a few on kijiji for fairly cheap, not sure if they are available, but I could hopefully get a 1/2hp one to upgrade it from the 1/3hp it originally had, however I can't get the damn plate for the sanding disk, and thus the pulley as well, off of the damn shaft, no matter how hard I try, and the shaft is some sort of tempered steel so I can't even drill it without it taking ages.
Anyways, can you just buy the pulley and plate for these? What is the proper term for the plate the sanding disk goes on?
