Author Topic: Can you name this top insert side screw PCB terminal found on Sonoff panels?  (Read 561 times)
Offline tomayrTopic starter
They are found in Sonoff NSpanel boxes on the relay board. PCB mount. Side screw.
I can't seem to find it for the life of me.
Offline spostma
not exactly the one you look for, but it looks like a single contact of a vertical entry terminal block like
https://www.metz-connect.com/externalfiles/311631/863662.PDF
By the way, this horizontal single contact block with 3.1mm hole, M3 screw and double mouting pin can be used for many mechanical mounting solutions:
https://www.metz-connect.com/home/products/u-contact/pc-board-terminal-blocks/screw-type-terminal-blocks.7f.en.html?id=360410
Offline ZigmundRat
« Last Edit: October 03, 2023, 08:42:50 pm by ZigmundRat »
Thank you for the responses so far.
It's odd that it wouldn't be a more readily available item. I scoured all of Metz's brochures and website as they seemed to be the most likely to manufacturer such a piece. I can't imagine its unique to Sonoff?
