That socket is a recent addition, and is typically only used for double isolated equipment, like phone chargers and other 2 pin devices. You only get the earthed version in a wall outlet version that also includes the regular 16A 3 pin outlet as well, and I have never seen an extension cord for that that is not integral to equipment or is only for double insulated equipment. As well it is mandatory on all installations to have earth leakage protection on all socket outlets, irrespective of age. You can have a house with fuse wire on the board and a small box with the earth leakage breaker next to it, and it will be passed so long as the wiring still meets minimum insulation levels ( good luck doing that with 50 year old DCC wire though, there you will rewire in all probability) and you still have the original 5A and 15A outlet sockets and nothing added over the years. Any new stuff has to comply with current standards.
