Author Topic: gerbers Gerbers GERBERS ahahhhhhhhhhhhh  (Read 2733 times)
Offline snipersquad100Topic starter
    • Electrinics
« on: June 08, 2014, 02:21:07 pm »
Me again    :-+ I know i'm going to piss a few ppl off writing this but I have no choice. sorry.
I thought I had this problem solved in my last post.
I've designed another pcb to get manufactured, but when I get it checked with https://oshpark.com/ it says theres no border outline.
The outline is there on my eagle layer 20 "DIMENTION" and when I do the cam processor it is active on all layers. So why is it not generating the outline. I've done a small test pcb which I link below but that said the same thing no outlind.  |O
https://app.box.com/s/hvnd4hi7l8wki0rk2qjn
Test file is here if someone could please check what im doing wrong.
Thank you.
Offline daveshah
  • Country: at
    • Projects
Re: gerbers Gerbers GERBERS ahahhhhhhhhhhhh
« Reply #1 on: June 08, 2014, 02:39:58 pm »
OSH Park require the outline layer to be .gko rather than .gml
    • Electrinics
« Reply #2 on: June 08, 2014, 02:47:15 pm »
OK, just tried it with zofcpcb and it worked. Thanks
been banging my head against the wall for nothing.
How do you find out what file type a specific board house needs?
    • Electrinics
« Reply #3 on: June 08, 2014, 02:58:47 pm »
Its working now thanks.
A trap for young players as Dave would say. :-+
Offline zapta
« Reply #4 on: June 08, 2014, 07:38:50 pm »
If you are using Windows, 'gerbv' is a simple to use and good gerber viewer.
One problem I noticed with some gerber viewers is that they will not show the outline if it's made of 0 width lines (gerbv does show it) so it safer to give it some minimal line width.
I also don't like gerbers, mostly because different vendors require different gerber settings.
Offline rexxar
    • Forever Tinkering
« Reply #5 on: June 08, 2014, 07:58:15 pm »
Well, for OSHPark, click the 'design rules' link in the top banner. There's the list of all the file names they need.
    • Electrinics
« Reply #6 on: June 08, 2014, 09:13:59 pm »
Thanks guys, And zapta that is a good tip, cheers
Offline zapta
« Reply #7 on: June 09, 2014, 04:15:19 am »
They also accept eagle .brd files directly.
