Testingeevblog-954-how-to-setup-an-electronics-lab-for-$300/msg1088467the-$250-electrnoics-lab-a-suggested-setup-for-beginners/msg265338
they work - how did you do it ? - if I copy your link they do not work ?You are doing what I do with Yahoo, highlight a section and paste in the link, but I do not know how to do that herethanks
[url=URL]Link text[/url]
Quote from: ez24 on December 11, 2016, 09:23:48 pmthey work - how did you do it ? - if I copy your link they do not work ?You are doing what I do with Yahoo, highlight a section and paste in the link, but I do not know how to do that herethanksI had to use the url tags like this: Code: [Select][url=URL]Link text[/url]For some reason the dollar sign messes things up -- could be something to do with the MathJax plugin?
This has been a problem for quite a long time now. No sign of it getting any attention. It isn't just "$" signs. Here is an example I cut from a previous post I made a while back. And my attempt to fix it.
goo.gl
I am going to have to learn how to do that.
Quote from: wilfred on December 12, 2016, 09:45:41 amI am going to have to learn how to do that.Click the "SHARE" icon on the side panel, and then check the "Short URL" box on the pop up dialog.
Wouldn't it be simpler for everyone concerned if there was a fix that could be installed? Why should everyone muck about working around this bug?
