Author Topic: Can't post a reply  (Read 348 times)
Offline Quarlo KlobrigneyTopic starter
  • Country: pt
  • This Space For Rent
Can't post a reply
« on: May 11, 2023, 11:24:01 pm »
The following error or errors occurred while posting this message:
The message exceeds the maximum allowed length (65535 characters).
Why?
Voltage does not flow, nor does voltage go.
Offline RoGeorge
Re: Can't post a reply
« Reply #1 on: May 11, 2023, 11:44:35 pm »
A typical textbook page has about 2000 characters.  64KiB would be a short novel.  I guess you were not writing that much.
By any chances, did you drag and drop any pictures into the reply?
Asking because some browsers may turn pictures into Base64 text.
If not, maybe a faulty or hacked browser.  :-//
I can reply just fine, didn't see any errors lately.
  • Country: pt
« Reply #2 on: May 11, 2023, 11:57:57 pm »
Yes, & Yes.
The post resolved itself if I removed the dimensions such as: 32x43x77 and separated the numbers.
I don't know if I did have success in drop and drop because at that point I did the find and attach inline.
Anyway, it's posted here. https://www.eevblog.com/forum/projects/euro-screw-terminal-block/msg4858772/#msg4858772
I've got SMF for my repair blog and it to is a bit wonky. :-//
