Based on your other electrolytic capacitors on the PCB you probably had it the wrong polarity, the top one is definitely the wrong way around!
oops. You jumped to the wrong conclusion.
Optical illusion. It definitely is not installed wrong.
I could take (and post) a series of photos that would show you this, but just take my word for it.
I can see in the photo where you get that, but it is absolutely positively installed correctly.
You are seeing print on the right side edge of the casing that looks like the negative bar but it is not.
The Negative bar is on the Left, just beyond the edge of the capacitor, and is indeed aligned with the white indicator on the PCB.
