Author Topic: Car alarm siren issue  (Read 1527 times)
Offline slybundaTopic starter
« on: February 04, 2024, 03:03:06 pm »
car alarm siren seems to have gone nuts looks like these pics explains it:
dunno where to begin on this. its a toad ai606 so not gonna be easy to find replacement.
Online mendip_discovery
Re: Car alarm siren issue
« Reply #1 on: February 04, 2024, 03:21:06 pm »
Personally, I would reach out to https://www.toadalarm.com/ and see if they might offer help/support.
Some of these places can be quite good at making an offer to repair/replace parts for not a lot.
Motorcyclist, Nerd, and I work in a Calibration Lab :-)
So everyone is clear, Calibration = Taking Measurement against a known source, Verification = Checking Calibration against Specification, Adjustment = Adjusting the unit to be within specifications.
Online PlainName
  • Country: va
« Reply #2 on: February 04, 2024, 03:49:10 pm »
its a toad
My, how restrained you are!
 8)
« Reply #3 on: February 04, 2024, 03:57:57 pm »
Will contact toad and see what they say. I thought these came with a lifetime warranty
« Reply #4 on: February 04, 2024, 05:06:54 pm »
more pics here
« Reply #5 on: February 04, 2024, 05:47:05 pm »
Ouch, leaky battery. I wonder if they created a short that killed the mosfet (or what ever they are).
Well and truly fooked.
« Reply #6 on: February 04, 2024, 07:32:54 pm »
I think those 3 mosfet looking things are transistors of some sort i wonder if they are like amplifiers for the they have a part number of tip32c. Brand may be just the F letter on it not sure what brand it is and there is also a 122 number on it.
Anyone know what it is and suitable replacement? Rs components in the uk is best for me since i can drive down and collect.
The resistors, am i right in thinking a resistor with single black band is 0 ohm?
Offline tom66
« Reply #7 on: February 04, 2024, 09:37:44 pm »
You can replace TIP32C with ... TIP32C.  It's a very common transistor made by many manufacturers.  Beware that resistor next to the transistor also looks damaged to me and the value is not obvious.
The 'F' is probably Fairchild.
« Reply #8 on: February 05, 2024, 07:17:41 am »
excellent i guess this one may work: https://uk.rs-online.com/web/p/bipolar-transistors/4859777?gb=s  ?
some resistors do look damaged im going to desolder stuff today hopefully the bottom side of the resistor that touches the pcb doesnt have burn marks so that i can see the bands on it.
« Reply #9 on: February 05, 2024, 10:43:51 am »
more pics after desoldering stuff,
« Reply #10 on: February 05, 2024, 10:58:13 am »
some trace damage too looks like a single layer board so not sure now.
Offline tom66
« Reply #11 on: February 05, 2024, 11:07:57 am »
The Jxxx numbering next to the suspect damaged resistors suggests they are jumpers.
I'd check the transistors next door were not thermally damaged, that board looks like it got toasty!
« Reply #12 on: February 05, 2024, 11:26:50 am »
zener diode is bust, not sure where to go with that, the 2 resistors although black seem to both be giving a resistance of 102 ohm and 101.5 ohm, so they could be 100 ohm resistors. all resistors marked with a Jxx measure at 0 ohms so they just jumpers i guess.
« Reply #13 on: February 05, 2024, 12:56:46 pm »
The other 2 transistors seem to test ok without removing them.
« Reply #14 on: February 05, 2024, 09:17:29 pm »
anyone know if the zener diode thats broken is part of the circuit thats responsible for charging the internal 7.2v battery? if so i can probably leave that part out of the circuit since i dont intend to put a battery back in it.
the other side where the traces have gone is the tricky part but its not micro soldering and has space to work around so may be able to just use wires to connect parts back up?
« Reply #15 on: February 08, 2024, 03:38:34 pm »
removed the sticker of the small chip and its got some markings on it:
12C508A
04/P01V
0113
maybe if i can find a datasheet for this it may give schematic info of whats supposed to be connected to it and how?
Offline tom66
« Reply #16 on: February 08, 2024, 03:43:16 pm »
That's a PIC12C508A microcontroller.  It's not going to be replaceable because it will have firmware embedded into it.  If you suspect it is fried, the whole device is scrap, unfortunately.
Online coromonadalix
« Reply #17 on: February 08, 2024, 04:02:01 pm »
unless  by some miracle they forgot to lock the mcu from being read ...     no luck to recover the firmware
Offline tom66
« Reply #18 on: February 08, 2024, 04:34:55 pm »
Yes, if they forgot to lock it, but even if it is unlocked if the MCU has been killed by something failing in the circuit board, it is unlikely to be able to connect to the programmer anyway.
« Reply #19 on: February 08, 2024, 06:12:21 pm »
what can i use to try and read the code from the chip? would it work with an arduino uno or one of those ch340 things?
also i dont think it is dead because the siren still worked as in if i hold the panic button on the key fob the alarm goes off making its usual sounds.
Online Zero999
  • 0999
« Reply #20 on: February 08, 2024, 07:19:03 pm »
I've got one of these. It works, but getting the software to play with Windows 10 isn't straightforward.
https://www.ebay.co.uk/itm/285338791568?chn=ps&_ul=GB&_trkparms=ispr%3D1&amdata=enc%3A1jw06wFvKTdykemi3JplpQQ35&norover=1&mkevt=1&mkrid=710-134428-41853-0&mkcid=2&mkscid=101&itemid=285338791568&targetid=1647205088280&device=c&mktype=pla&googleloc=9046050&poi=&campaignid=19688986533&mkgroupid=146538074536&rlsatarget=pla-1647205088280&abcId=9307891&merchantid=138357265&gclid=CjwKCAiAlJKuBhAdEiwAnZb7laoIozbhaBS6r-13ZqKm4EaIish6QtMlL8o1UtriS_71ozLqCSyeyBoCnmgQAvD_BwE
« Reply #21 on: February 08, 2024, 07:34:24 pm »
can it be run from a windows 7 or xp machine in a vm?
Online Zero999
  • 0999
« Reply #22 on: February 08, 2024, 10:12:10 pm »
Probably. The software is quite old and designed for Windows XP I think. I had trouble setting up the USB port. If I remember rightly, it uses one of those dodgy USB to serial/parallel chips.
« Reply #23 on: February 09, 2024, 05:13:47 pm »
So did Toad Alarm not offer to help?
« Reply #24 on: February 10, 2024, 03:03:59 pm »
Toad alarms said they can sell me a replacement siren which is at a ripoff price. No warranty since alarm comes with 1 year warranty and iv had it for over 20 years.
