Author Topic: Car Manufacturers Ruined a Serial Communication Protocol  (Read 1445 times)
Offline MuhScopeBrokeTopic starter
« on: May 23, 2022, 03:27:55 pm »
CAN has gone to the wind now that you can't source the IC necessary to interface with it. Most of my companies serial communication has now moved towards I2C/DI2C in light of this but some older parts still use CAN and its been impossible to find components. Very tough on us little guys who just need a simple CAN transceiver
Offline Scrts
  • Country: lt
Re: Car Manufacturers Ruined a Serial Communication Protocol
« Reply #1 on: May 23, 2022, 05:00:06 pm »
As of now:
TJA1041 - 2492 @ Digikey
TJA1043 - 145 @ Digikey
TJA1046 - 5875 @ Digikey
TJA1054 - 13472 @ Digikey
I did not check TI or Infineon PNs... Did not check Mouser or Newark...
Maybe buy in advance now?
Offline langwadt
« Reply #2 on: May 23, 2022, 05:09:12 pm »
LCSC has tens of different can transceivers, most of them with +10000 in stock ...
Offline tooki
« Reply #4 on: May 26, 2022, 04:13:12 pm »
You’re whining that car manufacturers “ruined” a bus standard designed by an auto parts supplier expressly for use in vehicles?  :-DD
The following users thanked this post: hans, thm_w, JPortici
Offline Jeroen3
  • Embedded Engineer
    • jeroen3.nl
« Reply #5 on: May 26, 2022, 04:21:24 pm »
Lol
CAN tranceivers are made everywhere, they are big silicon, no need for tsmc. iirc even the aged philips fab in nijmegen can make them.
https://nl.farnell.com/microchip/mcp2551-i-sn/ic-can-transceiver-hi-speed-smd/dp/9758569?st=mcp2551
69.509 In stock
12.000 meer zal beschikbaar zijn op 15-10-22
15.200 meer zal beschikbaar zijn op 16-12-22
15.200 meer zal beschikbaar zijn op 20-4-23
But try getting an MCU with CAN....
Online tom66
« Reply #6 on: May 26, 2022, 04:33:00 pm »
Try getting an MCU!   Getting it with CAN is just icing on the cake!
Offline eugene
« Reply #7 on: May 26, 2022, 07:00:44 pm »
I've used MCU's with CAN peripherals, but they all still require an external transceiver. They handle (some of) the ugly details of the protocol, but they can't drive a bus. (Ralph Kramden, where are you?)  Are there MCU's with built in CAN transceivers?
90% of quoted statistics are fictional
Online tom66
« Reply #8 on: May 26, 2022, 07:24:41 pm »
I've certainly seen an MCU on an ECM which had CAN traces going directly into it, implying they do exist.  It was an automotive-specific Freescale chip with of course no datasheet publicly available.
This probably requires quite a large amount of die space and I wonder how resilient these are to the common faults, like 28V directly to CAN_H/CAN_L which is something most transceiver chips survive.
Offline hans
« Reply #9 on: May 27, 2022, 07:09:01 am »
LPC Cortex-m0+ series also had an integrated CAN transceiver.
I also see 100k MCP2551 CAN transceivers in stock at Mouser. They work just fine and are a bargain.
How you replace CAN with I2C I don't know. Please don't I2C offboard, would'ya? It's an EMC and troubleshooting nightmare.
