Author Topic: Cheap, easily available, 1.27mm/1.25mm pitched wire to board cable assemblies?  (Read 603 times)
Offline InfravioletTopic starter
Any tips for good options for cheap and "generic" (available from multiple manufacturers, the way 0805 resistors or 7400 series ICs are) cable assemblies (premade and precrimped) and corresponding board headers (though hole types desired). I've used things like molex picoblades in the past for this sort of thing, but they are awfully pricy and I'm working on something which will use quite a lot of these, plus a lot of the length and conductor count combinations aren't seemingly available right now. I'm interested in 2,3,4,6 and 12(or higher up to 16) way options particularly, and I'm after single row types not grids or the shifted grids of some ribbon cables which in practice have two sets of 2.54mm connectors pitch shifted by half. Any suggestions of the names of any such connector and cable series? As I said, ideally generic due to all the logisitical difficulties inherent in buying pretty much anything specific which comes from only a single manufacturer thesedays. Thank you
Online Someone
    • send complaints here
https://en.wikipedia.org/wiki/Flexible_flat_cable
Cheap, multi-source, variety of conductor counts....
Through Hole? well thats not where the volume market is, so you dont get the benefits above.
Thanks for the tip, turns out there are through hole* FFC compatible headers, just one trouble though, FFCs can't snake around complex shapes in 3D. Yes, you can do some cunning fold angles, but they can't bend in multiple directions at once the way a wire or ribbon cable can.
*I do use SMD stuff, but for connectors I always swear by through hole, just incase more force somehow gets applied to it than one intends.
