Author Topic: Cheap Iron for hobby stuffs! Hakko or Weller £150ish  (Read 881 times)
Offline Terry01Topic starter
  • Country: scotland
« on: January 23, 2018, 09:48:40 pm »
I am going to get myself a new soldering iron so am looking for some help deciding.
I have a Katsu 852D just now, the small blue one with hot air station. It's in good nic and does the job fine but I have heard people saying Hakko/Weller stuff is like night and day compared to the cloned irons. I will keep the Katsu as a 2nd/back up iron and use the hot air attached to it for SMD stuff. I am happy enough with the Katsu for any SMD work for now.
The Katsu is my 1st iron so I've only used that and have nothing to compare it to. I don't do a load of soldering but will be nice to have a proper iron if they really are that much better.
The Katsu uses a Hakko knock off iron and I use genuine Hakko tips in it and they made a noticeable difference to the cheap tips that come with the Hakko clone iron.
That's a tip for anyone using the Hakko clone iron too by the way...get a genuine Hakko tip for it and see the difference it makes. Well worth it i'd say, the iron holds it's heat so much better and is much better to use. I got mine from PROTO-pic UK, well worth the extra ££!!
Sparks and Smoke means i'm nearly there!
Online wraper
  • Country: lv
Re: Cheap Iron for hobby stuffs! Hakko or Weller £150ish
« Reply #1 on: January 23, 2018, 09:56:28 pm »
ERSA I-con nano is exactly in your ballpark https://www.amazon.de/Ersa-Nano-Digitale-L%C3%B6tstation-0IC1200A/dp/B002MQLJ46/ref=sr_1_1?ie=UTF8&qid=1516744349&sr=8-1&keywords=i-con+nano
Way better than any weller or hakko you can get for this money.
The following users thanked this post: tooki, Terry01
  • Country: scotland
« Reply #2 on: January 23, 2018, 10:14:06 pm »
Nice one! Check your pm buddy.
