Author Topic: cheap opamps with offset like TLE2141 ?  (Read 2311 times)
Offline lordvader88Topic starter
« on: June 14, 2019, 07:50:25 pm »
I'm looking for some opamps that can have offset voltages added, like for circuits with relays and hysteresis. The circuit I could make uses TLE2141
http://www.ti.com/lit/ds/slos525/slos525.pdf
They're $3.5 each, I'd like to get something cheaper, any idea's ?
I order some LM1458 today, I currently have a few other types, for now I guess I have enough GP opamps.
Offline exe
  • self-educated hobbyist
Re: cheap opamps with offset like TLE2141 ?
« Reply #1 on: June 14, 2019, 09:25:41 pm »
Virtually any opamp is fine, including lm358, tl072, etc. See http://www.ti.com/lit/ug/tidu020a/tidu020a.pdf or google "opamp comparator hysteresis".
The following users thanked this post: lordvader88
« Reply #2 on: June 16, 2019, 06:11:14 pm »
So I don't need a special op-amp with offset pins, I can find another circuit for that ok, even better
Offline exe
« Reply #3 on: June 16, 2019, 09:24:32 pm »
These offset pins are not even used...
The following users thanked this post: Ysjoelfir
Online Zero999
  • 0999
« Reply #4 on: June 17, 2019, 07:55:40 am »
The op-amp is being used as a comparator, so the TLE2141 is not the best IC for the job. A comparator IC such as the LM393, LM311 would arguably be better, although the circuit would need to be changed slightly because they have open collector outputs, rather than the push-pull output of an op-amp. An even better option is to use a comparator with a push-pull output such as the LMC6762 or TLC3702.
« Reply #5 on: July 04, 2019, 10:22:40 pm »
It is being used, the power is on another page.
But either way, Ive seen a few circuits using these opamps with an offset, so I was looking for a generic model to buy
Offline Dbldutch
« Reply #6 on: May 04, 2022, 08:57:25 am »
Lordvader88, You use a circuit diagram that was taken from my Blog.
It has no indication where you took it from, or who the owner/designer is which is unethical to say the least.
Please don't do that and respect the work of others.
You don't except PM's which is why I had to do it this way.
« Last Edit: May 04, 2022, 08:59:19 am by Dbldutch »
Online Zero999
  • 0999
« Reply #7 on: May 04, 2022, 09:20:02 am »
The original poster has been banned, as indicated by the emoji.
Anyway, he used image tags to insert the schematic, which I don't consider to be unethical because the url reveals where he got it from. I believe there ways to prevent your content being used in this manner if it bothers you.
The following users thanked this post: Dbldutch
Offline Dbldutch
« Reply #8 on: May 04, 2022, 10:46:02 am »
Thanks for the quick reply. It does't bother me, since it's an old and no longer relevant circuit, but the source should be mentioned. I don't see the image tags though, just as a matter of interest, how do I get to see them?
Thank you!
Offline timenutgoblin
« Reply #9 on: May 04, 2022, 10:57:53 am »
Online Zero999
  • 0999
« Reply #10 on: May 04, 2022, 11:09:24 am »
Thank you!
Click on the quote button to see the source code used to make the post. I don't know  much about website design, but I'm aware of ways to prevent people from accessing files on your server, unless they load the page. It's certainly something to investigate, if it offends you.
Regarding the original topic: why use the TLE2141 as a simple comparator? It's a daft idea: way overkill. There are much cheaper, better suited alternatives, such as the LMC7211, which is designed to be used as a comparator. The only reason a sane person would use the TLE2141 is if they have loads in stock and no comparator chips to hand.
« Last Edit: May 04, 2022, 11:12:19 am by Zero999 »
Offline Simon
  • Global Moderator
    • Simon's Electronics
« Reply #11 on: May 04, 2022, 12:17:07 pm »
If you are that bothered put you blog address on the picture.
The following users thanked this post: EEVblog, egonotto, thm_w
Offline Dbldutch
« Reply #12 on: May 04, 2022, 01:04:42 pm »
Yes, that is the link, good find. This was a prototype Curve Tracer based on an a very old commercial DIY design. It evolved over a few years into a very good and much more complete design, credit to a small team. Links are in the blog.
The reason for the overkill Opamp instead of a comparator is simple. I had a large stash of these Opamps from another project and no comparators at the time. It worked and did the job for that project. The original design of the circuit wasn't really mine as you can see in the blog, but that is beside the point. I made sure credit was published where it was due. As we should always do.
I found the url of the original picture. Thanks. Unfortunately it gets to the original location, but doesn't really get you to the Blog post itself.
Never mind, I found this circuit and wanted to alert the user. 'Nough said, thanks for chiming in.
The following users thanked this post: timenutgoblin
