Mine is a cheap spring tension bar that I checked against a calibrated torque wrench tester and it agreed within 5% across the range, so i trust the reading from it. Not good at the low end, but fine up to 200Nm, and used a lot for machinery where I want a preset torque other than " tighten till it breaks and next time not so tight", or the calibrated wrist.
