Author Topic: Cheap upgrade for your multimeter, a pet peeve of mine corrected  (Read 9419 times)
Offline Lightages
  • Canadian po
« on: February 04, 2013, 05:47:19 am »
I have a pet peeve about some selector dials on many multimeters. The pointers on the dials have nice little grooves to show which end is the pointer, but why don't the manufacturers just add a little bit of paint and complete the design? This makes things much easier to see what is selected.
If you compare these to the standard faces:
From Frankie's ebay store
and
from tme.eu
you can see the the dials are much easier to see.
All you need to do is use some nail polish and get it into the groove. If the nailpolish gets outside of the groove don't worry too much. All you need to do is let it dry for 30 seconds or so and then wipe off the excess from the outside of the groove.
« Last Edit: February 04, 2013, 05:59:30 am by Lightages »
Offline Wytnucls
Re: Cheap upgrade for your multimeter, a pet peeve of mine corrected
« Reply #1 on: February 04, 2013, 07:24:12 am »
Yes, I have done the same to my multimeters, with some white ink pen. I think our fading eyesights might have something to do with it!  :'(
White nail polish? You're very hip; I still only use the pink variety. Boring, I know....  :-*
« Last Edit: February 04, 2013, 12:29:06 pm by Wytnucls »
Offline steve30
    • Stephen Coates' Homepage
« Reply #2 on: February 04, 2013, 03:20:20 pm »
Can't say the lack of paint ever bothered me on a modern multimeter, but I do like the look of it.
I just checked my Mastech MS8218 which I use a lot, and that has a piece of white plastic on the knob :).
Offline robrenz
  • Real Machinist, Wannabe EE
« Reply #3 on: February 04, 2013, 04:13:57 pm »
Nice touch! :-+  just the kind of obsessive attention to detail I like ;D
Online SeanB
« Reply #4 on: February 04, 2013, 04:19:39 pm »
If you have a teenage daughter ( mostly) then you can get every colour in nail polish in the room, from white to black and every colour and fluorescent variety in between, along with a lot of UV fluorescent ones.
Offline Lightages
  • Canadian po
« Reply #5 on: February 04, 2013, 04:42:00 pm »
Who needs a daughter? I have red, green, yellow and white. I have these to mark wires and plugs.
Offline codeboy2k
« Reply #6 on: February 04, 2013, 07:53:35 pm »
instead of nailpolish, paint or white-out/liquid paper, I think you might be the type to mill
a little brass insert for yours, sized for just the right press-fit
* codeboy2k waits for the video ;)
Offline Lightages
  • Canadian po
« Reply #7 on: February 04, 2013, 08:10:45 pm »
I could mill a piece of something to insert, but nail polish works very nicely!
Offline Matje
« Reply #8 on: February 04, 2013, 10:44:51 pm »
But, but, but - look at the thingies!
There is only one ambiguous position, between "Off" and "uA/A". And I'd guess the manufacturers figured that a switched off DMM is easy enough to spot... ;-)
In fact they could leave out the groove too where it not for blind users, .oO, naah, scratch that. Or do DMMs with speech output actually exist?
Aesthetically though the white stripe is a winner in my opinion.
Offline jaqie
  • Genuine Girl Techie
« Reply #9 on: February 04, 2013, 10:49:28 pm »
Very nice.   I miss when they actually bothered to do things like this.
Offline robrenz
« Reply #10 on: February 04, 2013, 11:01:19 pm »
I usualy use epoxy with a filler. I use boron nitride powder for white and carbon black for black like in my push button restoration here. Sorry these pictures will have to do :'(
Offline codeboy2k
« Reply #11 on: February 04, 2013, 11:39:59 pm »
Wow. just wow.  I'm speechless.  I've not seen that thread before, you really did a fantastic job on that 30yr old tek scope.  My hat is off to you, sir!
good job!  :-+
Offline RamboJj
  • EE/biomed Student
    • FloridaStreetScene
« Reply #12 on: February 04, 2013, 11:47:27 pm »
I like my Extech, it has a larger white arrow shape on it. It just works nicely...
Speaking of which, I need to put some new batteries in it...
Extech EX330, X-Tronic 6040 rework/soldering station and a hole bunch of other junk...
-Jeff personal site / blog JjP
Offline Lightages
  • Canadian po
« Reply #13 on: February 05, 2013, 12:02:20 am »
You might want to read up on the Extechs on this forum and then open yours up to be sure you didn't get something unsafe, even if it does have a nice white arrow.
Offline robrenz
« Reply #14 on: February 05, 2013, 12:11:18 am »
good job!  :-+
Thanks, glad you liked it.
Offline RamboJj
  • EE/biomed Student
« Reply #15 on: February 05, 2013, 01:40:17 am »
already did that. mine is fine and works great.
Online rsjsouza
  • Eternally curious
    • Vbe - vídeo blog eletrônico
« Reply #16 on: February 05, 2013, 02:17:35 am »
Oh, no! Why did you bring this up?!? Now I won't be able to sleep until I paint the small dot on my Fluke 179...  :-BROKE
Online BravoV
  • +++ ATH1
« Reply #17 on: February 05, 2013, 05:06:38 am »
Did mine years ago at one of the cheapo dmm using white correction fluid, it was bright white when was new, now it turned into yucky yellow. For sure it will stay there forever.
Just make sure you wipe the excess fluid fast before it dries up completely, quite difficult to clean at the bumpy surface once it completely dried, remember did quite some buffing job to clean it up.
Offline T4P
  • Country: sg
    • T4P
« Reply #18 on: February 05, 2013, 04:59:07 pm »
How about white silicone? I don't have the white variety but ;) A small dose of correction fluid and put a tiny layer of clear silicone which is apart from the super-strong high temperature red silicone that i have
And oh, that bucket of white paint  ;) Just remembered i have a U1273AX on the way to me and it does have a white pointer!
Offline ivan747
« Reply #19 on: February 06, 2013, 02:01:34 am »
Reminds me of Dave's early rants on bad product design, beck when he had less than 50 episodes  ^-^
Offline WorldPowerLabs
« Reply #20 on: February 06, 2013, 06:54:18 pm »
That mod looks great on those meters!  My most-used meter is actually an old Radio Shack model with a white housing.  It has a nice, bold black line on the selector switch to indicate position.  Very easy to notice.  My other meters are black with no contrasting pointer; I'll have use your trick on them.
I'm sure that 99% of folks here already know this, but you can also use nail polish on the heads of screws to keep them from vibrating loose -- just put a drop where the screw head meets the panel or whatever it screws into.  When screws are secured in this way, it's easier to break them loose later than if you were to use loctite on the threads (obviously, use the recommended loctite when it's critical that the fastener stay in place, but for most electronics uses, nail polish is perfect).
Offline RamboJj
  • EE/biomed Student
« Reply #21 on: February 07, 2013, 04:41:47 am »
This is a new one, I never heard the idea of using nail polish as a "loctite" type product. The problem for me though is I'm a 30+ male and it might be weird if I buy nail polish... LOL, I'd probably get some pretty interesting looks. I should pick up some funky colors just to make for better odd looks, hahaha
Offline PA4TIM
« Reply #22 on: February 07, 2013, 11:11:51 pm »
Buy a real meter >:D ,my Agilent U1252A has a big white dot on the knob. But besides that, the thing is made so the knob only points to one mode when not in off position. My Fluke 77-III does not have it but I never missed it. The pointing side is much more narrow as the other side.
Offline RamboJj
  • EE/biomed Student
« Reply #23 on: February 08, 2013, 02:30:52 am »
you got 350ish I can borrow? indefinitely.....
Offline PA4TIM
« Reply #24 on: February 08, 2013, 06:38:54 am »
Just take the bike instead of the car and save a few tanks of petrol and maybe a few weekends no beer, and you can make an investment that gives you joy for years. ;-)
But indeed, if you're a student it will be a lot of money, but, hey, the good news is, your time will come. When I was a student i also could only buy the most cheap meter, and in the 70's that was much more exensive as now ( to bad they most times broke down faster as i had money to buy another, but at college only two or three guys in our class had a car, today it seems every student has one, and a iphone, ipod and a lot of other exensive stuff so then it s natural a Agilent multimeter is out of range)
