Author Topic: Chinese Power Supply with Multiple V+ and V- Terminals  (Read 2426 times)
Offline RailroaderTopic starter
« on: March 22, 2014, 01:36:43 am »
I have just purchased a generic 12V 10A Power Supply from China on eBay. The photos show that it has two V+ terminals and two V- terminals. Does anyone know whether these are two separate outputs with independent over current monitors or are just one output with two sets of terminals for convenience?
Offline Monkeh
Re: Chinese Power Supply with Multiple V+ and V- Terminals
« Reply #1 on: March 22, 2014, 01:41:05 am »
You tell us when you get it..
Probably just ganged terminals, though.
Offline VK3DRB
« Reply #2 on: March 22, 2014, 06:26:09 am »
You better check it is safe. The communist Chinese flog a lot of dodgy equipment on eBay. Some of it is downright dangerous (I had seen examples of this). Some of it has safety approvals printed on the box or case, but it is fraudulent. Some don't even have safety approval labels at all. In Australia a lot of stuff is bought on eBay and illegally imported from third world countries like China.
I suggest before you do anything, open the power supply up and check for case earthing, bad solder joints, poor insulation, loose screws etc. Fix anything that looks dodgy.
Before you plug anything into the output, check the + and - are not reversed and is at the expected voltages.
Offline amyk
« Reply #3 on: March 22, 2014, 01:30:02 pm »
Open it up and look at the PCB, that should tell you.
