Author Topic: Chip of the day!!!.........  (Read 6611 times)
Offline SmokeyTopic starter
  • Not An Expert
« on: July 09, 2023, 09:04:16 am »
Find an interesting/useful part?
Think other people will also think it's interesting and/or useful?
Post it here.
Chip of the day!
  • Not An Expert
Re: Chip of the day!!!.........
« Reply #1 on: July 09, 2023, 09:05:09 am »
LM7705 Low-Noise Negative Bias Generator
https://www.ti.com/lit/ds/symlink/lm7705.pdf
3V-5.25V Input
-0.23V Out at about 20mA
Good for those "RRIO" opamps if you actually need actual RRIO
Only $0.86 in 1s at Digikey
https://www.digikey.com/en/products/detail/texas-instruments/LM7705MMX-NOPB/2020262
The following users thanked this post: Kean
Online Warhawk
    • Personal resume
« Reply #2 on: July 09, 2023, 10:07:49 am »
I like OPA991 family (or the 992 upgrade). Quite a universal opamp.
Online Warhawk
    • Personal resume
« Reply #3 on: July 09, 2023, 10:09:21 am »
3V-5.25V Input
I like this one LM27762
  • Not An Expert
« Reply #4 on: July 09, 2023, 09:10:02 pm »
3V-5.25V Input
Nice.  That must be a new part.  it's not in webbench yet.
One thing to watch out for is the positive output is just LDO down regulated from the input voltage, and the negative output is inverted from the input voltage and then LDO regulated.   So you can't have +/-5V from a 3.3V input (even though it sort of looks that way from the banner specs).
If you actually need +/-5V from something like 3.3V input, this would work:
TPS65133
https://www.digikey.com/en/products/detail/texas-instruments/TPS65133DPDR/
https://www.ti.com/lit/ds/symlink/tps65133.pdf
QTY UNIT PRICE
1 $2.56
Offline Benta
« Reply #5 on: July 09, 2023, 11:32:00 pm »
I have several favourites, but the latest is the TI LM2660 (and LM2662). Not new, but to me they are.
+/-5 V from a single USB +5 V input with just two caps.
I love it!
The following users thanked this post: ROT
Offline floobydust
« Reply #6 on: July 10, 2023, 01:12:11 am »
3V-5.25V Input
Um all that work for -0.23V? I am confused...  The ICL7660 came out in 1980 and gave more, like -5V.
  • Not An Expert
« Reply #7 on: July 10, 2023, 07:48:32 am »
3V-5.25V Input
There is a good answer to this one.  Say you are using a single supply opamp like the TL900x series:
https://www.ti.com/lit/ds/symlink/tlv9002.pdf
It has a supply range up to 5.5V.  If you are already running it from a +5V rail and all you need to actually output 0V, then you only have at most -0.5V that the negative rail can be.  Since you only need about -20mV for the supposedly RRIO to be able to drive to 0V, the -0.23V of the LM7705 is more than enough to keep the opamp in the recommended operation range and drive 0V out.
« Reply #8 on: July 10, 2023, 08:38:40 am »
Magic little SOT23-6 dual complementary MOSFETS....pick your poison.
Typically pins 2 and 5 are Gate inputs which makes them a challenge to route but certainly not impossible, even with home etching.  :phew:
Used them for power device gate drivers for years and some will warn you about shoot through but never had this issue.
I use them at logic levels as both a driver and level shifter for which they have been brilliant, even gate driving 200A IGBT's.  :o
Gate charge is typically very low so with care driving them from 4000 IC's is simple.
Just one randomly selected:
https://www.farnell.com/datasheets/2300062.pdf
YMMV
The following users thanked this post: Exosia
Offline Someone
    • send complaints here
« Reply #9 on: July 10, 2023, 08:47:52 am »
TI are iterating on "universal opamp" with others like OPAx828, or chopper OPAx189 lots of progress with analog capabilities still growing.
Offline SiliconWizard
« Reply #10 on: July 10, 2023, 09:39:30 pm »
3V-5.25V Input
Yes, but it's not just about being enough for the job - it can achieve a significantly lower output ripple than the venerable ICL7660. Hence why it's marketed as "low noise".
Online nctnico
« Reply #11 on: July 10, 2023, 10:22:53 pm »
Currently I'm quite pleasantly surprised by the abilities of the ESP32-S3 chip. Only downside I've seen so far is the crappy ADC but other than that the software ecosystem is nice, well documented and the chip is very capable.
Offline VK3DRB
« Reply #12 on: July 13, 2023, 07:28:59 am »
You are right, the ESP32's in general are great other than the ADC. Super low cost and unlike other MCU suppliers (Microchip, TI and STM), I could get ESP32-C3's during COVID - and that is the reason I used them in two projects, albeit at risk. Also used an ESP32-S3-WROOM. You can calibrate the ADC's but still they are mediocre at best. No good for accurate analogue measurements, but I did use it on one project for a non-critical battery fuel gauge (could not get fuel gauge chips during COVID) and it was OK.
Espressif's BLE documentation is a dog's breakfast. Their hardware datasheets has ambiguity in them and is missing some detail that would be found in, say, TI and Analog Devices datasheets. The ecosystem is satisfactory but not great. Mind you I recently found a glaring pin-out error in Texas Instruments two year-old chip that no-one at TI had even picked up. The pinout list showed input pin for CAN bus data incorrectly described as a chip enable pin :wtf: TI's documentation QA is in trouble if such an error can exist for two years before they know about it. Overall Espressif does a reasonable job with their English documentation, considering it is a Chinese company.
No complaints though, because ESP32's got me out of a bind during COVID. Super low cost, which is good for high volume cost-sensitive projects. Plus I learnt to use a new MCU.
Online Warhawk
    • Personal resume
« Reply #13 on: July 13, 2023, 11:27:34 am »
Which TI chip? I get it fixed.
Offline Simon
  • Global Moderator
    • Simon's Electronics
« Reply #14 on: July 13, 2023, 12:33:38 pm »
Post it here.
Chip of the day!
No thanks, I want them to be available tomorrow  ;D
The following users thanked this post: Ed.Kloonk, Circlotron, Brumby, Ian.M, ANTALIFE
Online Warhawk
    • Personal resume
« Reply #15 on: July 13, 2023, 02:15:09 pm »
Post it here.
Chip of the day!
You know, that's difficult. You can submit documentation feedback as shown in the attachment.
Offline Simon
  • Global Moderator
« Reply #16 on: July 13, 2023, 06:08:28 pm »
I don't think documentation feedback will help with supply.
Offline VK3DRB
« Reply #17 on: July 15, 2023, 08:02:50 am »
The ISOW1044BDFMR. I did report it about 3 weeks ago, and to TI's credit they fixed it immediately and re-released the document. Pin 3 was listed as a chip enable when it was in fact a transmit data line.
I find it incredible no-one else has ever used this chip, of if they have, they are too busy or self-centred to report the error. Mind you, if I reported every bug in Altium, I'd never get any work done.
  • Not An Expert
« Reply #18 on: July 15, 2023, 08:47:59 pm »
Wow.  Those are some impressive specs..  but at $6.30 in 1s... Not quite universal prices...
https://www.digikey.com/en/products/detail/texas-instruments/OPA4189IDR/15857137
  • Not An Expert
« Reply #19 on: July 15, 2023, 10:44:59 pm »
Datasheet from TI shows revision date of Dec 2021.  Pinout for Pin3 shows it correctly as TXD. (Enable shows as Pin8).
https://www.ti.com/lit/ds/symlink/isow1044.pdf
TI document control almost certainly is ISO9001, which makes revising a document but not bumping the revision essentially impossible.
Offline tooki
« Reply #20 on: July 16, 2023, 04:03:32 pm »
I was pleasantly surprised at TI’s responsiveness to datasheet errors. I once found an error in the website description of some weird version of the 5534 op-amp (perhaps a mil-spec version or somethinf), where it was described as a quad op-amp (it’s a single). They fixed it right away.
Offline tooki
« Reply #21 on: July 16, 2023, 04:10:29 pm »
The UTI (universal transducer interface) from Smartec.
https://smartec-sensors.eu/cms/pages/products/uti-interface.php
It can measure capacitance down to a 2pF range (14-bit resolution) over long cables, more or less regardless of cable capacitance. I used it (in the 0-300pF range) to measure the level of liquid xenon in a cryostat through 3m of coax cable (at 100pF/m). Measurements reproducible down to 0.02pF with averaging.
It can also do resistance, e.g. for PT1000’s.
Downside is that it’s hard to find. None of the major distributors carry it any more, so you have to find a small local distributor.
Offline griffinadams
  • I would have routed cardiac nerves differently.
    • Engenious Design
« Reply #22 on: July 17, 2023, 03:02:51 pm »
Nice. Quite a useful part, unfortunate name...
Along the same lines, TI has the TDC7200 for ultrasonic timing measurements.
https://www.ti.com/product/TDC7200
Griffin Adams | Senior Electrical Engineer
www.engenio.us
Offline tooki
« Reply #23 on: July 25, 2023, 03:58:51 pm »
Ain't that the truth!  ;D
Neat!
  • Not An Expert
« Reply #24 on: August 31, 2023, 03:49:58 am »
Chip of the day = TMP1075
https://www.ti.com/lit/ds/symlink/tmp1075.pdf
https://www.digikey.com/en/products/detail/texas-instruments/TMP1075NDRLR/15222310
$0.64 in 1s, $0.25 in 4000s.
-40°C ~ 125°C Range, I2C Interface, Tiny SOT-563 package, Thermal Alert Output.  Measure thermal load or ambient temp with a cutout.
