Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
General
General Technical Chat
Chip shortage? DIY: miniaturize transistor based electronics?
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: Chip shortage? DIY: miniaturize transistor based electronics? (Read 948 times)
RES
Regular Contributor
Country:
on:
April 28, 2022, 08:36:08 pm »
What if chip shortages keep becoming more of a problem in the future, can hobbyists create their own "chips" (very small/thin printed circuit board) by using the smallest SMD transistors available today VML0806 package?
How far can a hobbyist create their own miniature transistor based electronics? And you have to be good in designing circuits with the least possible miniature components. (without expensive industrial equipement)
https://duino4projects.com/wp-content/uploads/2015/02/Rohm-claims-to-have-smallest-transistor-package.jpg
Logged
RES -
https://www.youtube.com/@RES2313/videos
Kleinstein
Super Contributor
Country:
Re: Chip shortage? DIY: miniaturize transistor based electronics?
Reply #1 on:
April 28, 2022, 08:46:31 pm »
Even with small SMD types a circuit can fast get quite large. There are a few cases where discrete transitors may replace an OP or 2, but this often comes at the cost of high power consumption and size. More normal OP's are still available and it would be mainly more special cases (e.g. > 40 V) where on may consider a dicrete build version. Similar one may go back to JFET switching instead of CMOS switches in some cases.
Another problem with a discrete build solution is that it usually more time to design and not many are used to such types of designs.
To allow debugging the first iteration tends to be relatively large to have extra space for probes and bodges / resistor changes.
Discrete parts are also a bit limited when it comes to small, low capacitance transistors.
Logged
jwet
Frequent Contributor
Country:
Reply #2 on:
April 29, 2022, 04:47:46 pm »
It's "possible" but not especially practical.
Checkout the "
https://monster6502.com/
"- a 6502 CPU made discretely- only 12x15" and a lot of time. By Eric Schlaepfer- he estimates cost at about $3k, mostly labor.
Logged
Sredni
Country:
Reply #3 on:
April 29, 2022, 09:12:19 pm »
well, for hobbyist purposes only, I find it oddly satisfying to use discrete multivibrators, essential comparators, and small op amps (basically a differential amplifier with a buffer stage, and if I am in the mood a current source for biasing) to do very basic stuff. Not because I need, but only because I can.
Seeing the multivibrator working with a 0.7 volts supply was... nice. Try to do that with a 555 or a microcontroller.
But for practical purposes... ICs are much more robust. One would need a lot of discrete transistor to add all the functionality we take for granted.
A link to a site that offers discrete op amps:
http://www.nanovolt.ch/resources/discrete_opamps/index.html
Last Edit: April 29, 2022, 09:22:41 pm by Sredni
Logged
John B
Country:
Reply #4 on:
April 29, 2022, 09:20:35 pm »
It sounds like a nightmare cycle of committing to a design, getting the PCB, assembling the board, then wanting to tweak something small to change a minor aspect of the functionality, then back to step one....
Logged
jwet
Country:
Reply #5 on:
April 30, 2022, 12:44:48 am »
Imagine committing to launching an IC into a fab. The cost to make a set of masks for a modern IC is unbelievable (millions) but committing any IC to a fab is big gamble. Lots and lots of simulation is the standard answer but not everything shows up. Committing to a PCB is nothing in comparison.
Logged
Someone
Super Contributor
Country:
Reply #6 on:
April 30, 2022, 01:11:25 am »
Start by finding the actually smallest package. I'll drop the bar a little lower:
XDFN3 0.42x0.62mm
Add in some embedded and/or printed in PCB components and you're getting there.
But how granular do you need to go? Many digital logic, opamps, and comparators (much larger functional blocks) are already multi sourced and or interchangeable with other model numbers. Engineering, balancing n different competing priorities.
Logged
SiliconWizard
Super Contributor
Country:
Reply #7 on:
April 30, 2022, 01:57:30 am »
Many things can't be efficiently implemented with discrete transistors.
For instance, most discrete MOSFETs (but a few exceptions) available do have their source and bulk internally connected. That causes issues for implementing a lot of stuff.
Logged
Sredni
Country:
Reply #8 on:
April 30, 2022, 02:28:56 am »
Also current mirrors are a pain to implement with discrete transistors. One needs to do a bit of selection to get the best matching. On a die, the matching is a direct consequence of being created there.
Logged
Print
Search
Pages: [
1
Go Up
« previous
next »
General
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
