Hi folks.
Recently I did a bunch of XT60 connectors for my outdoor solar panel extender cable and found that my decade old 250g 0.8 ПОС61 solder spool is coming to en end.
ПОС61 is a Soviet/Russian naming for Припой Оловянно-Свинцовый which literally mean nothing more then "tin lead solder with lead content of 61%". Everyone who started doing electronics in Soviet or early post-Soviet era is 100% familiar with this stuff - no exceptions. It is often made to standard by unknown manufacturer (at least the most vintage ones), the old one come in 2-3 mm diameter "wires" and some times in 8mm bars with no flux added. This thing just does the job and this is all to be said about ПОС61 solder even now days. It melts at expected temperatures of about 190-200 C, spreads in controlled way, gives you some blurry solder joint and that's it. Just add some ethanol (no, vodka will not do!) dissolved rosin as a flux and you're good to go. Characteristics will vary slightly from sample to sample: not the lowest melting temperature, not the best wetting, not the most perfect shiny joint, but it cheap (in most cases free), always work and never fail in any way regardless if it is half century old noname spiral you got from your father's wooden box they days trees were taller and skies were blue or a new spool you got from marketplace delivered to the nearest pick point next day (or on the second day if you're unlucky).
I use my 0.8mm ПОС61 with rosin core for my general work. I also have Asahi 0.25mm spool for SMD, but it looks like that 0.25 will last me a lifetime as I tend to.. be lazy and use 0.8mm even for 0102.
Things changed when I got Quick 202d inductive soldering station really cheap for black Friday sale. I also got "knife" and "microwave" tips for it and that changed my soldering experience so much that I was thinking of selling my old and trusty Goot RX-711AS with a bunch of chisel tips (no, I'll keep it). Suddenly I realized that I don't need to keep iron tip at 340-360C any more - the 90W (it is actually 100W) induction heated thermocouple controlled tip pumps heat into the tip and reacts to temperature changes so fast, that I'm in most cases good at 300C or even less for leaded stuff. No overheating to compensate for low power and slow reaction of ceramic element with sensor deep inside is needed. The short finger-to-tip distance is another thing I like about Quick 202d. There some (many!) disadvantages, but this is another story.
OK, now I have a better control of my iron tip and can keep it at a lower temperatures because of different heating technique and more power involved. This brought me to idea I should try some potentially better solder as my current one is almost over and it may be a good point I can improve my soldering even more.
So, I started searching for one to fulfill my requirements. Nothing special, actually: I need leaded solder with flux for a general PCB work. I always use additional flux for my work (for general stuff I prefer rosin-based RusFlux Souze-Apollon that is unexpectedly good for the money and for BGA I have a decade old EFD FluxPlus 412).
For sure we have all sorts of ПОС61 still available and according to youtube comments good manufacturers are known. But what I found is that many reputable import (as well as some local) manufacturers produce two common types of solder at the same time (among "special" ones): this are 63/37 and 60/40. Asahi does this, Kester does this, Cynel does this, Kaina does this. Pretty sure others do as well, but my manufacturers list is limited to what I know and can get locally.
So, let put Soviet 61/39 aside and now my question is what is the reason for manufactures to produce 63/37 and 60/40 solders simultaneously and what is a real practical differences?
The second (optional) question is: why "special" solders have some 1-2% silver or copper added and is it worth paying extra for such solders?
