Author Topic: Cleaning stainless steel (with home made cleaners)  (Read 2457 times)
Offline Halcyon
« on: May 31, 2018, 10:22:52 am »
Stainless steel is everywhere. My kitchen appliances are covered in the stuff, however I refuse to pay good money for a few hundred millilitres of a so-called specialised stainless steel cleaning products from the supermarket. I've tried them before and they barely do a better job compared to water alone. Probably just marketing bullshit.
Does anyone have any effective home-brew recipes for cleaning oily deposits like cooking oil and fingerprints from stainless steel and aluminium surfaces that I can make up in a spray bottle?
Offline JohnnyMalaria
    • Enlighten Scientific LLC
Re: Cleaning stainless steel (with home made cleaners)
« Reply #1 on: May 31, 2018, 10:44:20 am »
Some white vinegar in water with a drop or two of washing up liquid.
Tell me it can't be done and I'll do it. Or give it a damned good try.
Offline DimitriP
« Reply #2 on: May 31, 2018, 10:44:51 am »
Sponge with dish soap. The trick is to use the right kind of microfiber towel to wipe it dry.  Some microfiber towels tend to stick to rough skin more than othes. That's the "right kind".
I  also use Meguiars Express synthetic wax for extra shine.  wurks gud :)
To me the most significant ingredient seems to be the microfiber towel.
Online Ian.M
« Reply #3 on: May 31, 2018, 11:03:08 am »
See https://www.bssa.org.uk/topics.php?article=77
One thing to be aware of is the possibility of slight surface rusting due to depletion of the protective Chromium oxide layer.  To resolve this you need to passivate the surface - etch away any Iron oxides and enough elemental Iron to raise the surface Chromium concentration.  There are various ways to do this, but probably the easiest it to use an Oxalic acid based cleaner.
Offline Ampera
    • Ampera's Forums
« Reply #4 on: May 31, 2018, 11:33:12 am »
IPA?
C/C++/Java Programmer, Legacy hardware enthusiast, madman.
If it's broken, I probably did it.
EEVBlog IRC: irc.austnet.irc #eevblog
Offline ChunkyPastaSauce
« Reply #5 on: May 31, 2018, 11:57:09 am »
After trying rubbing alcohol, glass cleaners, acetone, soap...for the hell of it I tried straight dishwasher rinse aid (finish turbo, dunno if it matters); works almost instantly for me
Online Ian.M
« Reply #6 on: May 31, 2018, 12:11:30 pm »
IPA?
:popcorn:
Isopropanol isn't terribly effective as a degreaser for heavily oil, grease or wax soiled surfaces, especially when the residue is a drying oil (e.g. many vegtable oils, especially after heating in a metal pan) that can form varnish-like deposits.
India Pale Ale is likely to be even less effective - 5% to 10% Ethanol in water isn't going to do much for grease removal, even with the slight boost the carbonation gives it and possible slight saponification due to the hops.
Its much more effective self-applied internally post-cleaning as an incentive to apply a more appropriate cleaner with enough 'elbow-grease'!
OTOH, while we are on a brewery theme, Bar Keepers Friend will do a good job on stainless surfaces that aren't extremely highly polished.
« Last Edit: May 31, 2018, 01:38:26 pm by Ian.M »
The following users thanked this post: The Soulman
Offline Ampera
    • Ampera's Forums
« Reply #7 on: May 31, 2018, 12:36:52 pm »
suggestion: don't embed absolutely massive images into the forum, scale them down first. that filled up more than my entire screen on a 1920x1080 desktop.
I've found that it works quite well for degreasing, but if the situation is really so bad for that to not work well enough, then you'd need something like WD-40 to clean it, and I don't imagine Halcyon's steel is that dirty.
Online Ian.M
« Reply #8 on: May 31, 2018, 01:33:12 pm »
OOPS!!
Sorry I didn't notice as this forum auto resizes images in the browser to fit the page layout, and as I'd been to the linked Colonial Brewery page, it was already cached so I didn't notice the extended load time.  They are might proud of their cans to publish them at that resolution!
I'll attach a small version here and inline that instead.  If anyone has problems with that I'll replace it with a Creative Commons image of a different brand of IPA from Wikipedia . . . .
Offline BradC
« Reply #9 on: May 31, 2018, 01:48:40 pm »
70% Nitric acid works well. I also have a weak hydrofluoric acid paste that does a fantastic job. Both are probably overkill for the kitchen though.
Offline Gyro
« Reply #10 on: May 31, 2018, 03:14:18 pm »
...for cleaning oily deposits like cooking oil...
Depends how health your diet is. Worst case, Engine degreaser.  ;)
Chris
"Victor Meldrew, the Crimson Avenger!"
Offline Gyro
« Reply #11 on: May 31, 2018, 03:18:31 pm »
Isn't hydroflouric the one that eats your bones if you get it on your skin - tales of people having fingers and hands amputated after touching rubber components from braking systems in burned out cars etc.?
Chris
« Reply #12 on: May 31, 2018, 03:54:09 pm »
HF is like the Energizer bunny (which they stole from Duracell) - it keeps on going and going. Not only does it do all the horrible things you say but it acts as a local anesthetic, too, as it burrows through your flesh so you don't even know it's there.
I've got conc. HCl and conc. nitric in a cupboard less than two feet in front of me. Mix those and you can dissolve gold. I have much respective for these things.
Online Gregg
« Reply #13 on: May 31, 2018, 07:21:58 pm »
The powdered cleanser called Barkeeper's Friend is the best bang for the buck and leaves a nice shine without making more scratch marks (unless it is a mirror finish; then use Simichrome polish).  Simichrome is also great for loading a knife sharpening strop.
Offline CopperCone
  • *knock knock*
« Reply #14 on: May 31, 2018, 07:35:40 pm »
I don't wash appliances often but I think that stainless steel wipes are pretty good. I can't get the same results with other methods. I  find the spray tends to streak and you require more elbow grease and time to get the same finish as the wipes. Convenience seems to pay.
They have a kind of mildly abrasive texture I have not seen elsewhere, which makes the job go quick.
I also love lineman's wipes or whatever their called. Like grime-away. They are very rough, like a cats tongue,  but it cleans gummy oil and shit super good. It does not seem to 'clog up' like with a paper towel (I tend to use the thicker blue 'shop towels') when used on heavy grease. Then I wipe away the chemical its soaked with using a regular paper towel.
I have a feeling you will have a shit time doing any kind of polish/cleaning without specially textured towels.
I really think your problem is texture. The roughness of the wipes seems to kind of 'grind off' grease, hard to imagine but you can defiantly feel a difference vs the spray. I don't think regular bounty or other paper towels are appropriate.
The ones that they sell in a stack, folded into three sections (like how you mail a letter) work pretty well with the spray, but not as good as the wipes, even though they are harder then the wipes. I think they are less absorbant.
« Last Edit: May 31, 2018, 07:38:38 pm by CopperCone »
Offline TheSteve
  • GHz
« Reply #15 on: May 31, 2018, 07:53:16 pm »
Not home brew but the "go to" cleaner in the bonnet of most DeLorean owners seems to be Windex - it always worked well to get rid of the finger and hand prints from those who insisted on touching the stainless.
VE7FM
Offline BradC
« Reply #16 on: June 01, 2018, 12:21:07 am »
Yeah it is. This is a couple of percent in a thick gel. Commonly used for cleaning up stainless after an improperly purged or shielded weld. It's fairly aggressive, but no more so than other fairly noxious chemicals. It does a spectacular job in removing almost anything from stainless.
I must say the only thing in a car I thought would produce HF when burned was the refrigerant in the AC and the only damage I'd heard of was it etching the windscreen. I've not heard of tissue damage. Chlorinated products break down to hydrochloriic acid and occasionally phosgene (which isn't much fun at all).
Offline CopperCone
  • *knock knock*
« Reply #17 on: June 01, 2018, 01:07:38 am »
Hydrofluoric acid is potent poison and skin rot agent. As a organic eating acid, it is weak.
It does not kill you by burning instead of seeps into the skin, like DMSO, into fatty tissue, and causes calcium to precipitate.
This causes lysis of cellular matter and I believe clogs your heart.
In a gel form, it is probably safer, because it does not penetrate the skin as rapidly, you can wipe it off to minimize exposure, but expect to lose flesh, like a spider bite, at the very least.
I would recommend through wiping rather then washing. If you spread it out, the contact with your skin is larger. It is surface area dependent. In-fact I would recommend carefully scraping it off with a razor as to minimize spread before smearing it around to get rid of it (keep in mind the HF molecule will already have diffused through your skin some what and you should get medical treatment).
Keep in mind, the dose absorbed through inhalation is rather small, compared to the massive dose you would receive with skin contact. Don't take the fact that breathing some fumes won't kill you as it being safe for contact.
« Last Edit: June 01, 2018, 01:15:20 am by CopperCone »
« Reply #18 on: June 01, 2018, 01:26:04 am »
To clarify a point that often confuses people: "weak" doesn't mean it's feeble and relatively harmless. The scientific meaning of it being a weak acid is that it doesn't dissociate fully into H+ and F- ions but exists in an equilibrium with HF molecules. A strong acid is almost fully dissociated. Hydrochloric acid is a strong acid and, at a given concentration, has a lower pH than hydrofluoric acid. Even citric acid is lower than HF. But it's not just the pH that'll get you.  I'd much rather have to deal with HCl than HF any day.
Online IanB
« Reply #19 on: June 01, 2018, 01:26:25 am »
A trick that I learned is mineral oil. You can buy this either in the kitchen department for treating cutting boards, salad bowls and other wooden food utensils, or in the healthcare department as unscented baby oil (which apparently is not made from babies).
Simply wipe down stainless steel surfaces with a paper towel soaked in the mineral oil. It will easily dissolve and remove finger prints and other greasy marks and leave the steel with a nice even sheen. Wipe off any excess oil with a dry paper towel. The remaining film of oil will also protect the steel from further marks like finger prints and smudges.
If the steel has any calcium deposits from hard water, you can wipe it down first with a solution of kettle descaler followed by a good rinse with clean water and a thorough drying before using the oil to polish it.
« Last Edit: June 01, 2018, 01:30:12 am by IanB »
The following users thanked this post: ChunkyPastaSauce
Offline Zero999
  • 0999
« Reply #20 on: June 04, 2018, 12:37:26 pm »
The hazard associated with HF has little to do with it being and acid and everything about it being highly toxic and easily absorbed through the skin.
Offline dwpaulver
« Reply #21 on: June 29, 2018, 04:08:36 am »
Try these varieties of homemade stainless steel cleaner. https://homeremediesfor.com/cleaning-stainless-steel/#j_Windex
Offline DTJ
« Reply #22 on: June 29, 2018, 04:23:25 am »
Try wiping the stainless over with a tiny amount of kerosene after you've cleaned it with soapy water, vinegar or whatever.
There's expensive stuff in a silver spray bottle you can buy (I can't recall its name at the moment) but its main ingredient seems to be kerosene.
A small spray and rubbing it over with a cloth leaves a very thin layer maintains a shine  and aids in cleaning next time.
Offline darrellg
« Reply #23 on: June 29, 2018, 05:58:12 pm »
I'll second the recommendation for Barkeeper's Friend. All of my cookware is stainless steel and that stuff is like magic on it. It's very inexpensive.
https://www.barkeepersfriend.com/
Offline tooki
« Reply #24 on: June 29, 2018, 07:08:36 pm »
FYI, the secret to keeping stainless steel free of fingerprints is to not degrease it! Stainless steel cleaners often contain a bit of suspended oil to effect a thin layer of oil. This way there’s less contrast with fingerprints. (Same thing in cleaners for matte LCD screens, by the way!!)
I suspect you could mix up one yourself with some blend of water, IPA, and a few drops of silicone oil. Just give it a vigorous shake before applying!
