Author Topic: Deoxit D5 alternative ?  (Read 4470 times)
Offline FlumpTopic starter
« on: January 10, 2015, 06:56:19 pm »
I have a new Antenna Tuning Unit and every now and then the Roller Inductor needs cleaning
and the manual states to use Deoxit D5 but thats quite expensive for someone i will only use
now and then so I wonder if there is a cheaper alternative ?
Here is the manual for it, the very last section covers the cleaning
http://www.palstar.com/en/product-manuals/manual_at2k.pdf
Offline torr032
  • Country: ba
Re: Deoxit D5 alternative ?
« Reply #1 on: January 10, 2015, 08:54:47 pm »
Use Teslanol T6.
Offline babysitter
  • pushing silicon at work
« Reply #2 on: January 10, 2015, 09:41:29 pm »
Yes, Teslanol T6 seconded!
If it is really heavy dirt, give it a run in the dishwasher.
« Last Edit: January 10, 2015, 09:48:55 pm by babysitter »
I'm not a feature, I'm a bug! ARC DG3HDA
Offline nanofrog
« Reply #3 on: January 10, 2015, 09:44:26 pm »
Might want to consider Cramoline Contactaclean as well (originally called Cramolin Red).
As it happens, this is similar, if not identical to the active compound in DeoxIT, which has an excellent reputation here in the US (story here).
Conrad UK sells it:
200ml spray can
400ml spray can
« Reply #4 on: January 12, 2015, 01:14:19 pm »
Hi babysitter, the tuner wont fit in my dishwasher but i have a jetwash  :-DD
Thanks very much for the advice guys  :-+
