Author Topic: Clearly a conspiracy  (Read 1457 times)
Offline akisTopic starter
« on: June 12, 2023, 04:43:50 pm »
Tape measures are made specifically to be as awkward to use as possible. The only way they will stay is on its flat side, and most times you want the damn thing just to stay upright, nothing more, but no, they have a specific shape with rounded edges and bumps and curves so as never to just stay there. Most infuriating. Typical example. I want to work with lengths of, say 1.3m. My aluminium ruler is 1m, so I have to use the tape. Nothing wrong with that, I will simply open it out to about 1.5m and that will give me plenty of room to work with up to 1.3m. But no. The damn thing will not stay anywhere I leave it and the smallest nudge or movement and it's tipped over again ruining all the alignment and readings! It is a conspiracy, plain and simple.
The following users thanked this post: David Aurora, Siwastaja
Offline Bud
Re: Clearly a conspiracy
« Reply #1 on: June 12, 2023, 04:52:59 pm »
If that is poor in your books, try self-leveling laser levels   ;D, you can't breath at them
Offline AndyBeez
  • Country: nu
« Reply #2 on: June 12, 2023, 05:02:34 pm »
1. Blame Coriolis https://en.m.wikipedia.org/wiki/Coriolis_force
2. Get a longer rule.
3. Cut shorter lengths.
« Reply #3 on: June 12, 2023, 05:09:54 pm »
Ha ha I have, as I am building a house and have tried to align door frames, windows, ceilings and floors. I have about 5-6 of them and have already dropped 2-3 :-(
They need very stable mountings and a lot of patience to set them where you need to, very soft touch and hold your breath. Literally. For example I used a handsaw hanging upside down on a nail in the wall as a base for the magnetic laser level. Trying to set that assembly up is an exercise in patience. You cana see I am using 3 lasers to help align a door frame, one is on the floor, the other on a tripod and the other on the hanging handsaw blade :)
I have also discovered. You need to align it to within 1 degree, preferably less, *before* you unlock the pendulum, and only then let the pendulum do its magic. Because, if you are out by say one degree or more, the pendulum will still align, but not as well as when you started off at 0.5 degrees. They usually self-align from 3 degrees downwards, but I would not trust them.
The following users thanked this post: Bud
Offline TimFox
Offline m k
« Reply #5 on: June 12, 2023, 05:24:18 pm »
Keep in mind that laser is quite easily bending around a mass.
Advance-Aneng-Appa-AVO-Beckman-Danbridge-Data Tech-Fluke-General Radio-H. W. Sullivan-Heathkit-HP-Kaise-Kyoritsu-Leeds & Northrup-Mastech-OR-X-REO-Simpson-Sinclair-Tektronix-Tokyo Rikosha-Topward-Triplett-Tritron-YFE
Offline EE4all
« Reply #6 on: June 12, 2023, 05:39:42 pm »
Then your foundation settles a little, and all your leveling and squaring is off   :scared: :-DD
Offline mendip_discovery
« Reply #7 on: June 12, 2023, 06:15:16 pm »
Build it all wonky so wonky that you can say it was a design choice.
You know you can buy 2 and 3m steel rules. Just take in for temperature changes when measuring stuff.
Motorcyclist, Nerd, and I work in a Calibration Lab :-)
So everyone is clear, Calibration = Taking Measurement against a known source, Verification = Checking Calibration against Specification, Adjustment = Adjusting the unit to be within specifications.
Offline TimFox
« Reply #8 on: June 12, 2023, 06:21:04 pm »
A more convenient and reasonably-priced option:
https://www.mcmaster.com/19365A27/
Many years ago, when installing an x-ray system in another State, I brought a six-foot English/metric tape measure with me.
A local electrician, installing the x-ray on light, asked to borrow my tape.
He opened it, saw cm along one edge, and handed it back to me.
Offline Infraviolet
« Reply #9 on: June 12, 2023, 07:19:41 pm »
You can always get a "tailors" type of tape measure, plastic flexible tape with the lengths marked on it. It will stay where you leave it. Typically have a metal end tip to add some weight, and as it isn't sprung the way a reeled tape measure is you could just old the tip down with blue tack.
Offline PlainName
  • Country: va
« Reply #10 on: June 13, 2023, 03:31:41 pm »
Offline EPAIII
« Reply #11 on: June 14, 2023, 08:57:03 am »
I clearly see your problem, right there in your post. "1.3m", "My aluminium ruler is 1m...", "1.5m", etc.
My tapes measure inches and feet and I have no problems with them.   ;D
Paul A.  -   SE Texas
And if you look REAL close at an analog signal,
You will find that it has discrete steps.
Online jpanhalt
« Reply #12 on: June 14, 2023, 10:00:38 am »
Typical example. I want to work with lengths of, say 1.3m. My aluminium ruler is 1m, so I have to use the tape. Nothing wrong with that...
The obvious solution is an adjustable length ruler -- not tape (attachment).  Aka, "carpenter ruler."
I also have a 6 foot aluminum fixed ruler that is helpful for layout, marking, and cutting straight edges for intermediate lengths where laser or chalk line isn't convenient.
