Author Topic: CNC Machine  (Read 9811 times)
Offline grimmjawTopic starter
CNC Machine
« on: May 07, 2015, 02:01:31 am »
I'm looking for a desktop cnc machine for light work such as milling Frontpanel, aluminium bracket, enclosure, mainly use  for prototyping.
the budget is ca. 5k€
Any suggestion is truly appreciated.
Grimmjaw
Offline PeterFW
    • Stuff that goes boom
Re: CNC Machine
« Reply #1 on: May 07, 2015, 02:21:42 am »
During my last search they came up often and looke pretty decent:
http://www.cnc-step.de/en/
But i do not own one, yet...
Offline rx8pilot
Re: CNC Machine
« Reply #2 on: May 07, 2015, 02:31:26 am »
When choosing a CNC machine to fit a budget - do not underestimate all the little bits you will need to make it work. Work holding, tool holders, cutting tools, etc.
Offline PeterFW
Re: CNC Machine
« Reply #3 on: May 07, 2015, 02:39:19 am »
Oh... yes!
There are so many damn things you need besides the machine.
Clamps, nuts, bolts, cutters, lubrication, wrenches, a vice, calipers, straight edges, parallels, drills, collets, vaccuum, threa cutters/dies and so much more...
And then you need stuff to mill, aluminium and plastic blocks are not cheap.
And you need a sacrificial table cover, some times.
At around 3.5K you get a decent machine, that leaves 1.5K for the various other stuff.
That could work.
Re: CNC Machine
« Reply #4 on: May 07, 2015, 03:36:46 am »
The litte thing ('verbrauch material') is included in the budget. Hopefully  I can get machine
will relatively 'plug and play' with the budget
Offline Tandy
  • Darren Grant from Tandy, UK.
    • Tandy
Re: CNC Machine
« Reply #5 on: May 07, 2015, 07:13:24 am »
Don't be tempted by the cheap machines on eBay as they are not up to the job of Aluminium. They are typically not sturdy enough and the DC 'spindle' is nothing more than a cheap dremil type thing that is just not cut out for it.
For more info on Tandy try these links Tandy History EEVBlog Thread & Official Tandy Website
Offline Galenbo
Re: CNC Machine
« Reply #6 on: May 07, 2015, 10:04:50 am »
Things that come to my mind when hearing CNC:
Cutting surface cooling
Machine Cooling
Dust retraction
Noise enclosure
Automatic greasing
Chip disposal
Milling speed (m3/h)
Wanted accuracy, precision, repeatability, squareness.
How to 'zero', how to re-clamp and continue, when needed.
Maybe all/some are unrelated here, but it's important to know that even 5K machines often still are toys.
Engraving will work, but better forget brackets and metal 2.5D stuff.
If you try and take a cat apart to see how it works, the first thing you have on your hands is a nonworking cat.
Offline rob77
  • Country: sk
Re: CNC Machine
« Reply #7 on: May 07, 2015, 10:18:13 am »
one route could be a cheap small plug&play CNC machine for engraving panels + milling plastic (basically a "toy" desktop CNC mill)  and in addition buy an old school manual milling machine for the metalwork - you can get a "decent" smaller milling machine suitable for metal work  for something like 1-2k Eur.
Offline Galenbo
Re: CNC Machine
« Reply #8 on: May 07, 2015, 10:23:03 am »
CNC? Brand and model?
For the price you mention, you only have the automatic greasing installallation that you will need for it.
Offline rob77
  • Country: sk
Re: CNC Machine
« Reply #9 on: May 07, 2015, 10:42:53 am »
no CNC, a smaller milling machine...
Bernardo is making a lot of them:
http://www.bernardo.at/shop/en/metal/metal-working/drilling-and-milling-machines/drilling-and-milling-machines.html?price=1000-2000
and of course they have sub 1000Eur ones as well.
The following users thanked this post: all_repair
Offline kc9qvl
Re: CNC Machine
« Reply #10 on: May 08, 2015, 03:48:57 am »
What size footprint and how large a milling area x,y,and z?
Try to stay away from the cnc routers. Most struggle with aluminum. Get a small but heavy mill.
If you don't want to diy convert a mini or micro mill to cnc then this.
http://littlemachineshop.com/products/product_view.php?ProductID=3501&category=1241045623
Small but usable. Going smaller would be the Sherline/Taig mill. Then the proxxon mf70. The proxxon would require conversion to cnc.
« Last Edit: May 08, 2015, 04:13:31 am by kc9qvl »
Offline rob77
  • Country: sk
Re: CNC Machine
« Reply #11 on: May 08, 2015, 05:30:23 am »
proxxon mf70 is a small & cute micro-mill - suitable for jewelry or making small/tiny parts. wouldn't buy it for making metal cases - the Y travel is just 35mm (i'm using the KT70 cross-table which is used on MF70 as well).
Offline pickle9000
Re: CNC Machine
« Reply #12 on: May 08, 2015, 06:41:38 am »
good advise
Offline Fred27
    • Fred's blog
Re: CNC Machine
« Reply #13 on: May 08, 2015, 08:29:49 am »
It's possible to modify the MF70 to increase the Y travel up to the 82mm limit caused by the throat of the mill. The required parts can be mill on the MF70 itself.
https://0xfred.wordpress.com/2012/04/17/extending-the-mf70s-y-axis/
It's a great mill, but it is tiny. It's surprising how often that is big enough though - or that you can design around the limitation.
Re: CNC Machine
« Reply #14 on: May 08, 2015, 08:47:28 am »
@kc9qvl
The mill from littlemachineshop looks promising but they only ship to US and Canada only.
I'm in Singapore actually
I have a friend with the proxxon mf70, and look like a solid enough machine.
But the Z-axis has some backlash that get me worried cutting aluminum or steel
Offline kc9qvl
Re: CNC Machine
« Reply #15 on: May 09, 2015, 03:54:46 am »
The backlash has no bearing on the machines ability to do aluminum or steel. Just not so good for precision.
Offline abigbell
Re: CNC Machine
« Reply #16 on: May 09, 2015, 04:24:03 am »
you  should try get one from chinese market,
there are some quite decent machine with real reasonale price, like 1000 us dollar can buy you some machine can chew alumiunm, even soft iron materials.
plus the shipment fee , probably cost 1500 us dollar, oh yaeh, some times earlier  I was trying to get one, so i did some rearch.
but eventually I got one like this with $300, just mess around with pcb \ arcylics\some pine wood.
?dont know how to insert pics? :phew:?
Offline rob77
  • Country: sk
Re: CNC Machine
« Reply #17 on: May 09, 2015, 10:44:45 am »
those are the CNC machines i was reffering to in my first reply - for engraving panels and milling pastic. and in addition to one of those buy a small non-CNC mill for serious metalwork.
Offline abigbell
Re: CNC Machine
« Reply #18 on: May 10, 2015, 06:27:40 am »
yes?i see?here are quite some choices in a wide range with different price?like this pvc toy i got
why all my punctuation mark are showing ???
« Last Edit: May 10, 2015, 06:29:40 am by abigbell »
Offline rob77
  • Country: sk
Re: CNC Machine
« Reply #19 on: May 10, 2015, 08:48:42 am »
yes that's a nice desktop machine for milling plastic and engraving ;) but it's not suitable for metalwork (if it was, then you would post a metalwork picture and not wood & PCB ;) )
anything what weights less than 40kg simply can't be stiff enough for milling metal with usable accuracy.
Offline abigbell
Re: CNC Machine
« Reply #20 on: May 11, 2015, 01:02:55 am »
yes,you are right, this is absolutely a "cheese/soap" engraver, I think the best it can deal with is palstic , over the PCB board.
I just dont want spend too much money on this thing, for me , I just toy it around.
I am total amature hobbyist, now the machine has been under my bed for a couple of weeks eating dust.
maybe someday I will custom make some decent steel to uograde its frame to do the real work. hopefully.
actually i just saw some sell this kit thing so cheeeeeeeeeaply, just buy. thing in china are relatively cheap.
300 us dollar for a fully function CNC mill,not a bad deal at all, :-+ even for a soap mill. :blah:
Re: CNC Machine
« Reply #21 on: May 11, 2015, 01:22:18 am »
@abigbell
look like a nice machine! :)
But I do prefer a machine that can cut aluminium, even though at a higher price
Offline abigbell
Re: CNC Machine
« Reply #22 on: May 11, 2015, 04:32:05 am »
@abigbell
ok, since you live in Singapore, just search www.taobao.com,I am sure you hear about it. I suppose you should read chinese.
from what I know, there several DIY individual sellers in taobao have some good quality machine which are very popular in domestic  market and developing contries such as Argentina, Brazil,even to usa,gemany, of course as cheap compromising option to the industrial high quality one. such as mine, as a kit version, you can assembly yourself. I use my old computer and second hand led power supply.
15mm thin pvc frame , 300w high speed air cooled spindle drill.
some amchine can deal with aluminium should have steady heavy steel frame,
thats heavy, maybe 60 kg to 80kg in total weight. that will cost your some money for shipment .
although the shipment fee should not be too much high, from mainland to Singapore . figure it out yourself.
Offline Tandy
    • Tandy
Re: CNC Machine
« Reply #23 on: May 11, 2015, 07:50:22 am »
This machine is quite good for basic aluminium work http://www.stepmores.com/product-55254a47bd04bfbf1c8b456d.shtml
It is still an aluminium machine but it is a solid cast aluminium machine with a moving bed instead of moving gantry. It has square rails that are on the cast base as opposed to round ones that sag in the centre. It also has a proper 1.5kw water cooled spindle.
Such a machine is not going to be used in a professional environment but it is a good compromise for a hobbyist between a toy bolted together extruded aluminium machine and an industrial heavy duty steal machine.
